[Ro...] Posted August 28 Share Posted August 28 Has anyone encountered this error when trying to do a full calibration with the ScanPort? I get this same error when it's on position 12. On the right side it says that it needs to decrease distance, but this is ScanPort automatic calibration, I don't have the option to move the sensor closer. Any guidance is appreciated. Link to comment Share on other sites More sharing options...
[Ri...] Posted August 29 Share Posted August 29 Please sign in to view this username. Is this a GOM Scan 1 or an ATOS Q? I ran into issues with the last GOM Scan 1 that I was using where the arm ran out of room to move closer. There was nothing I could do, so I ended up calibrating with the tripod. I believe there is a different mounting bracket for the GOM Scan 1 to the ATOSQ, so make sure you’re using the correct one. Link to comment Share on other sites More sharing options...
[Jo...] Posted August 31 Share Posted August 31 You could move the plate ... Which sensor and MV are we talking about? Link to comment Share on other sites More sharing options...
[Im...] Posted August 31 Share Posted August 31 Hi Roy , try moving the first starting position of the calibration plate up by about 1 cm so that there’s still space to move at position 12, then it should work. A similar problem occurred for us when calibrating the GOM Scan 1, of course make sure to check if you have the correct adapter installed (different one for the Atos Q and a different one for the GOM Scan 1). Link to comment Share on other sites More sharing options...
[Ro...] Posted August 31 Author Share Posted August 31 Please sign in to view this quote. Please sign in to view this username. It's on the GS1-200. I changed the mounting bracket, but I still get the same Issue. I reached out to the guys in NC and it seems to be a known problem. I ended up adjusting it by hand whiles it's still on the ScanPort. Thanks for the feedback! Link to comment Share on other sites More sharing options...
[Ro...] Posted August 31 Author Share Posted August 31 Please sign in to view this quote. It's the GS1-200. Link to comment Share on other sites More sharing options...
[Ro...] Posted August 31 Author Share Posted August 31 Please sign in to view this quote. Please sign in to view this username. I ended up adjusting it by hand, but I will give you suggestion a shot next time to see if it does the trick. I did switch the adapter but same issue. Thanks for the suggestion! Link to comment Share on other sites More sharing options...
