ScanPort Full Calibration Error
Has anyone encountered this error when trying to do a full calibration with the ScanPort? I get this same error when it's on position 12. On the right side it says that it needs to decrease distance, but this is ScanPort automatic calibration, I don't have the option to move the sensor closer. Any guidance is appreciated.
 Is this a GOM Scan 1 or an ATOS Q?
I ran into issues with the last GOM Scan 1 that I was using where the arm ran out of room to move closer. There was nothing I could do, so I ended up calibrating with the tripod.
I believe there is a different mounting bracket for the GOM Scan 1 to the ATOSQ, so make sure you’re using the correct one.
