[To...] Posted September 1 Share Posted September 1 I am running someone else's program and am getting this message at the end. Not using Multiple report, running 2019. Getting custom printout ok, just not a pdf. Also, pdf is grayed out in run window. Don't have pcm. Any thoughts about the error? Link to comment https://qualityforum.zeiss.com/topic/27332-formula-pdf/ Share on other sites More sharing options...
[Ca...] Posted September 1 Share Posted September 1 Hi Tom! Do you have the ZEISS PDF Printer installed? https://portal.zeiss.com/knowledge-base?id=402098 Link to comment https://qualityforum.zeiss.com/topic/27332-formula-pdf/#findComment-155074 Share on other sites More sharing options...
[Da...] Posted September 1 Share Posted September 1 Does anyone remember a post about compatibility settings? I can't find it. Link to comment https://qualityforum.zeiss.com/topic/27332-formula-pdf/#findComment-155114 Share on other sites More sharing options...
[Pe...] Posted September 8 Share Posted September 8 Here's a hypothesis: missing or incorrect formula in one of the "Name definitions for output files" windows. Go to Resources > Name for output files > ... for this Measurement Plan... Select "PDF File Graphics (custom report and plot)" from the drop down. Uncheck the "Name from setting for all Measurement Plans" box. Or if this needs to stay checked for this program, go into Resources > Name for output files > ... for all Measurement Plans... Select "PDF File Graphics (custom report and plot)" from the drop down. Make sure there's an appropriate path specified. 1 Link to comment https://qualityforum.zeiss.com/topic/27332-formula-pdf/#findComment-155372 Share on other sites More sharing options...
