Formula PDF
I am running someone else's program and am getting this message at the end. Not using Multiple report, running 2019. Getting custom printout ok, just not a pdf. Also, pdf is grayed out in run window.  Don't have pcm.  Any thoughts about the error?
Here's a hypothesis: missing or incorrect formula in one of the "Name definitions for output files" windows.
Go to Resources > Name for output files > ... for this Measurement Plan...
Select "PDF File Graphics (custom report and plot)" from the drop down. Uncheck the "Name from setting for all Measurement Plans" box.
Or if this needs to stay checked for this program, go into Resources > Name for output files > ... for all Measurement Plans...
Select "PDF File Graphics (custom report and plot)" from the drop down. Make sure there's an appropriate path specified.
