Normal vector extraction from plan
Hi everybody,
I have a workpiece to measure but don't have any CAD model of the part, and then no nominal vectors.
I would like to know if it was possible to extract the normal vector of a plane (after probing) and to put the values into the i, j and k vectors of a point feature.
That way, I'm sure I'll be measuring with the vector that's normal to the surface.
After a plane probing and generation, I just have the angle of it in the alignment (A1 and A2).
Thanks
Hi Richard,
When you define a plane you have x, y, z and a1, a2.
i attached a picture for example .
the file you shared is is awesome !
I will try to convert it manually but maybe someone how to proceed automatically in calypso.
Hi Yohan,
you could define a secondary alignment with your plan on spatial rotation, and use this alignment  for you point, so your point will be a i j k 001  in relation to your alignement/ plan
Hi Eric,
Thank you for your solution.
how I can show the vectors X, Y and Z instead of A1 and A2?
thanks
Select Preparation ➝ Features representation or click the icon in
the toolbar. Mark the feature before so that the desired geometry is selected. See "Checking or modifying the representation of features" in the manual.
