Flatness question
In the picture below, how would i report the |Flatness|.001/1.00 x 1.00|?
In the second pic, you can see the scanning paths I used.
If you don't have "Flatness ref." then i affraid it will be hard.
I think it is in 2018. On newer versions it's added even for curves
What's the difference between "Reference plane in each zone" and "Reference overall plane
I don't know which one to use, but i got to an explanation:
  • Refference plane in each zone:
    • You evaluate each zone independently - each zone has it's own tilt ignoring others
  • Refference overall plane:
    • It's determined one common plane and then each zone is evaluating only MIN/MAX point inside it's zone ( no tilt per zone )
Your FCF appears to want "Reference plane in each zone" as shown by "1.00x1.00".
Reference Plane in Each Zone = .001 per 1.00 × 1.00
  • Any local 1.00" × 1.00" inspection area must fit within two parallel planes separated by 0.001.
  • This could also mean sometimes you can't construct a 1.00x1.00 zone, maybe you get a .75x1.00 zone, etc. Each zone as closely related to 1.00x1.00 is treated the same.
I don't recall having to use the other method. But it seems like each 1.00x1.00 segment must be within ±.0005 within the entire surface used, not just per segment.
Another note:
The note "A 2 SURFACES" suggests the flatness may apply to two surfaces considered together. You should get clarification on that.
This may force you to use the latter description which I believe is stricter than each segment individually.
