[Ri...] Posted September 1 Share Posted September 1 7.500 OD , but 5.0mm pro will hit the 11.500 OD. 0.2mm pro will fit well, But can I use 500 Gauss Filter and 4250 points on 0.2mm pro to measure 7.500 OD. Link to comment https://qualityforum.zeiss.com/topic/27344-2mm-pro-using-5mm-pro-setting-point-and-gauss-filter/ Share on other sites More sharing options...
[Ch...] Posted September 9 Share Posted September 9 Depending on which probe head you are using (VAST XXT or VAST) the technical minimum stylus diameter is specified at 0.3mm, see below. You can still use a 0.2mm and I suspect you won't have any issues but it may be in your best interest to measure a ring gage after qualification just to ensure it is measuring accurately. 1 Link to comment https://qualityforum.zeiss.com/topic/27344-2mm-pro-using-5mm-pro-setting-point-and-gauss-filter/#findComment-155444 Share on other sites More sharing options...
[Ri...] Posted September 11 Author Share Posted September 11 Please sign in to view this quote. barcode for final seal scan.xlsxbarcode for final seal scan.xlsxbarcode for final seal scan.xlsx Link to comment https://qualityforum.zeiss.com/topic/27344-2mm-pro-using-5mm-pro-setting-point-and-gauss-filter/#findComment-155556 Share on other sites More sharing options...
[Ri...] Posted September 11 Author Share Posted September 11 I'm using xxt probe. using cookbook Link to comment https://qualityforum.zeiss.com/topic/27344-2mm-pro-using-5mm-pro-setting-point-and-gauss-filter/#findComment-155558 Share on other sites More sharing options...
[Ri...] Posted September 11 Author Share Posted September 11 Please sign in to view this quote. Link to comment https://qualityforum.zeiss.com/topic/27344-2mm-pro-using-5mm-pro-setting-point-and-gauss-filter/#findComment-155570 Share on other sites More sharing options...
