.2mm pro using 5mm pro setting point and Gauss Filter.
  • 2 weeks later...
Depending on which probe head you are using (VAST XXT or VAST) the technical minimum stylus diameter is specified at 0.3mm, see below. You can still use a 0.2mm and I suspect you won't have any issues but it may be in your best interest to measure a ring gage after qualification just to ensure it is measuring accurately.
XXTData.png.acae0ab1f84da7b297650226e5816ccd.pngVASTData.png.e87866e5460d9a33adbf042fd186b663.png
