How to ensure probe model in planner is in the correct position? (Stylus system creator/Planner/Simulation question)
Hello! I was recently informed that my company will be investing in planner and simulation so i can make programs while the CMMs are running. To prepare i have been trying to create the probe models off of stylus system creator.
Creating the probe models has gone well so far, but one probe setup i cannot find in the drop down menu and there is no documentation to confirm exactly what it is (the setup was created before i started working here) so i measured it and used the generic setups to create it.
Which leads to my main question, how can i be sure the placement of the styli on the model, is the same as the placement of the actual styli? I'm not very confident in the way i measured it, so I'm expecting it to be a little bit off. How off can it be for planner before it would start to cause issues? Is there a way to measure distances on the probe model, which i could then hard check to ensure it is the right probe setups?
I have just been going off of measurement and looks in order to find these builds since i have no records from my predecessors on what parts were used, so its likely that i selected the wrong one, and I'm worried that it can mess up programs i create via planner/simulation.
I will likely be asking more questions about planner/simulation once i actually have it in front of me so any advice is appreciated, thank you!
  • Like! 1
It depends on how much space is left between the probe and the part during actual measurements. Simulation does exctly 2 things:
  • Move the probe along the ideal (!) paths as defined by the strategies in the measurement plan
  • Check for collisons between the probe and the part on the way
It does NOT take actual measurements, which means, if it "scans" a 360° circle and the model has a gap or a bulge in the circle, it won't move into the gap or scan over the bulge (like a physical CMM would). It just follows the path defined by the strategy. In the case of the bulge it would then (falsely) detect a collision.
So you see that the realism of Simulation leaves a lot to be desired. That's why I wouldn't overrate the importance of a 100% correct stylus model. Of course it is best to use the correct elements, but I have more than one stylus where I use custom-made styli that are not even always 100% identical on repeat orders. I also put them together from generic elements and they work well. After all a programmer usually leaves a certain amount of safety space between probe and part if possible, so small deviations shouldn't matter most of the time.
Edited
  • Like! 1
Once you have your offline seat you should be able to update the stylus system offline to reduce false simulated collisions. So, even if you don't have the exact components offline you'll have the real world numbers from the qualification for that stylus system online. You can export the .pcf file from your online seat to a flash drive and then import it offline. After that, import the .ssc file to your planner and update the stylus system so that you have the graphics from the .ssc and the actual numbers from the .pcf
  • Like! 1
But as far as I know the collision detection always works with the stylus model, so even if you import the actual numbers from the physical CMM, it will ignore them for collision detection or even overwrite them with the ideal SSC values (hmmm, I never checked if the latter is true 🤔. I'd find it strange if Calypso would allow inconsistent values to coexist). If it would use the raw numbers for CD, it wouldn't be able to detect collisions of extensions etc., because they are not stored in a PCF.
Edited
I see what you're saying but I wouldn't overwrite the values, I'd want to update them. Order of operations would most likely play a big part too. Ideally, you'd already have the ssc file created and then you could update it with the pcf numbers from the actual stylus system. I don't normally use ssc files or simulations but it should work...in theory😎.
Sorry, but I still doubt it. 🤔The imported SSC model data is fixed and cannot be updated (as in "changed in dimension") through other data. The actual dimensions from the PCF may be present in the stylus list, but collision detection is still done with the original SSC model.
Edited
So, based on my understanding. I would load the PCF (which im assuming is the actual probe information from my online cmm, just confirming this im still pretty new) then import the SSC model in order for the program to be compatible with the online cmm, and to have a semi-accurate model for collision?
My main goal is to have all of our probes set up on this planner seat in a way to where i can edit or create programs on planner, and then import the programs into the online seat with little to no issues between probes. Currently we have no models created for our stylus systems so when I bring the stylus system PCF files into planner i would like to add in the SSC models i just created into the stylus systems.
Or would i just not bring in the actual stylus information (PCF?) and only import the SSC model, and make sure each probe is named the same as it is in my online CMM?
Got it. I was thinking it could use the graphics from the ssc AND the actuals from the pcf together but after some testing I realized you're right; it doesn't actually effect how the ssc functions or "update" it in a way to help avoid simulated collisions. It is possible to import the ssc into the existing probe file and update the system but it would still use the created ssc file for collision detection and the pcf file for the everything else.
 Norbert is also correct in that it's not a huge deal if the stylus system you built in creator is not identical to the one being used at the machine, depending on what kind of clearance you're working with. I.e. if your clearance cube is set to an inch outside of your CAD -- a couple mm difference in length won't really matter for moving around the part. It's just a nice visual and reference.
He also mentioned that you could use "generic" components when building a system in the creator if you can't find the exact length/size of component from the list. This seems like the easiest solution.
If you build the stylus system in creator and save it with the exact name (system and stylii) as they are online at the machine, the transition should be seamless.
  • Like! 2
Yeah I had to use that section for a couple of my probes lol, we have made some custom probes, and also have many designs that use components i cant find anywhere lol. I imagine my probe locations might be a couple thou off than where they actually are.
Great to hear that I can just name every probe the same and it will work. That's what ill do, Thank you very much everyone!
After re-reading your original post, I see that now😆 Good on you for making that work but yeah, I wouldn't sweat a couple thou!
Separately, are you CMMs running from a shared network? The reason I ask is because you'll run into the same issue on your planner seat when you try and open a program that is actively being run from a shared network, even though it's "offline".
Yeah all the programs are on a shared network, I have already read about people having problems with this, so Ill be making sure any programs being worked on wont be currently being ran, this will mainly be for creating new programs on a time crunch, but if needed i might edit the program from a different location so ill make sure they arent running that program. Thanks for the heads up!
Even if Calypso would allow to have different dimensions in the SSC and the imported PCF, I wouldn't reccommend to do that. Why? Because all the movements of the CMM are done based on the "actual" values in the stylus database, but collision detection is done with the SSC model data.
Having different values here could lead to false (or missed) collision warnings. Imagine your "actual" stylus is 0.1 mm shorter than the SSC model. If Calypso touches a point  on a surface based on the actual data, the tip of the SSC would already bump into the surface while the "actual" tip would barely touch it. Simulation would register this as a collision.
  • Like! 1
https://portal.zeiss.com/knowledge-base?id=552028
There are no issues running from a network as long as you have Calypso setup correctly. Quick fix. 🙂
  • Thank you! 1
This here was my main worry, i had to measure many components because I had no idea what some of the builds were (and some were custom) so i ended up just measuring each piece with calipers, then build the stylus model from that. After i would take the probe to a height gage or a Keyence and measuring the top of the probes to the base of the system, then just editing the numbers to match what i got with the height gage or keyance.
Suffice to say, not exactly a super precise way to measure the probes, but it was really the only thing i could think of because we had ordered the components from many different companies years before i started working here, and have no documentation on what it was we ordered. So my worry was that my actual probes would be different then the models i created and that it may cause the issues you mentioned.
I dont think Ill be able to do more with it until i get the planner dongle in and have the software in front of me (which i guess wont be for a couple weeks) because im thinking ill be able to find a way to get more information about the probe models i created when they are actually in planner (ruby locations and such)
I think you got me wrong here. What I described is not an issue between Planner and the real-world CMM, but a (hypothetical) issue in Planner itself. If you just don't bother about loading "real" PCF data into Planner and only use the SSC models instead, you're good and all that was said above will be true. Loading an SSC model will generate ideal probe data anyway, so no need to load a PCF at all.
  • Thank you! 1
