[An...] Posted September 2 Share Posted September 2 Can You help me. We learnig Inspect and has a problem with raports. We sort dimension with numbers on drawing but in INSPECT we cant sort as we'd like for example: circles is a top, next leght and angle is on bottom. How to sort it in order numers 1,2,3 etc? We try to create in order 1>2>3 but when nr.3 is a circle is autmoatic on first place, or angle had nr.4 and is on the bottom. Is the way to sort on principle drag and drop, or similar? See attachment. I hope You understand me. Sorry for language but I learn english 20 years ago 🙂 Thanks for help. 623-46AA.pdf Link to comment https://qualityforum.zeiss.com/topic/27350-reporting-on-inspect/ Share on other sites More sharing options...
[Ma...] Posted September 2 Share Posted September 2 Well i'm naming those dimensions with numbers - so "01; 115" and so on. I also write into keywords "qdas_k2001" and number of dimension for QDAS export. This value of keyword i then placed into this table as new column. Bad thing is that this change is more complex than it should be - you have to do it for XYZ, distances, gd&t and others. I am not sure if you can click on column to sort it ascending/descending - but it's alphabetically sorted. 1 Link to comment https://qualityforum.zeiss.com/topic/27350-reporting-on-inspect/#findComment-155194 Share on other sites More sharing options...
[Na...] Posted September 3 Share Posted September 3 Hello Andrzej, the table is sorted by the first column and the blue symbols for the elements are also used for sorting. As Please sign in to view this username. proposed, you could define an element keyword (ZEISS Quality Tech Guide) for the elements which is then used for sorting. There is also the possibility to define Inspection Balloons (ZEISS Quality Tech Guide), which can be used for sorting. Nanno 1 Link to comment https://qualityforum.zeiss.com/topic/27350-reporting-on-inspect/#findComment-155220 Share on other sites More sharing options...
[An...] Posted September 3 Author Share Posted September 3 Please sign in to view this username. thanks I try use numbers to sorting. Other ways are a bit complicated and I dont had any $ to do it for company, only do it to myself. Please sign in to view this username. Operations ► Elements ► and use baloons is the option, and also there are different options but I must had a time do do it. Thanks Guys i will combine on yours method. Have a lead Link to comment https://qualityforum.zeiss.com/topic/27350-reporting-on-inspect/#findComment-155260 Share on other sites More sharing options...
[Ma...] Posted September 3 Share Posted September 3 Please sign in to view this quote. Thanks for a hint. Unfortunatelly i am facing ballons like "01a /u" and some numbers are skipped. I would preffer to have something like "Annotation" to let me name it as i want and have access to it in table ( which now is not ) Link to comment https://qualityforum.zeiss.com/topic/27350-reporting-on-inspect/#findComment-155264 Share on other sites More sharing options...
[An...] Posted September 3 Author Share Posted September 3 I understand, but is stupid in Inspect there arent "drag and drop" option or similar. We working on eclipse and conturaG2 with Calypso 2025, and scanner is a new to Us. We had a training 2 days but is too short and we must by trial and error method. Anyway thanks for response. Link to comment https://qualityforum.zeiss.com/topic/27350-reporting-on-inspect/#findComment-155266 Share on other sites More sharing options...
