[Ke...] Posted September 3 Share Posted September 3 No problems in getting the Default PiWeb Reporting, it pops up on the screen after end of program. But then PiWeb continues to read and after a while the below message pop up. We're running with Calypso 7.6.20 and PiWeb 8.4.23.0? Link to comment https://qualityforum.zeiss.com/topic/27358-piweb-result-to-file-missing-1-protocolslog/ Share on other sites More sharing options...
[Ma...] Posted October 12 Share Posted October 12 Hello Kenneth, sorry for the late reply, do you save the PiWeb PDF automatically? If yes, does it work? Within the inspection plan folder is the mentioned protocols.log, if there is an error it should be visible there, maybe you can attach it here for a closer look. Best Regards Marcel Link to comment https://qualityforum.zeiss.com/topic/27358-piweb-result-to-file-missing-1-protocolslog/#findComment-156778 Share on other sites More sharing options...
[Ke...] Posted November 9 Author Share Posted November 9 Hi Marcel, Now i'm the one to reply late ☺ But many thanks for the feedback. We're still having the problem. We're not saving our reports from PiWeb, we upload our results as table files *.fet, *.chr, *hdr. These table files are grapped by our internal system. We only use Piweb during creation of our programs. This error only comes when we create new programs, if I run the "tactile_optical_adjustment_and_check_lin_V4.1_C7.4" from Zeiss, the report runs fine without any errors. I work with OI543 with RT-table and dotscan from 2024. The inserted clip below is from the inspection plan and as you wrote the error is listed in this file. Maybe a setting somewhere that needs a minor adjustment? Link to comment https://qualityforum.zeiss.com/topic/27358-piweb-result-to-file-missing-1-protocolslog/#findComment-158082 Share on other sites More sharing options...
[Ze...] Posted November 9 Share Posted November 9 Are you sure that the templates that PiWeb is using are installed in the correct location and that any paths that PiWeb is writing information to are accessible? Maybe it's trying to write the PDF file to a specific location, and it can't because it's write-protected and/or the location doesn't exist? Link to comment https://qualityforum.zeiss.com/topic/27358-piweb-result-to-file-missing-1-protocolslog/#findComment-158098 Share on other sites More sharing options...
[Ke...] Posted Friday at 08:10 AM Author Share Posted Friday at 08:10 AM Thanks for the input. I've checked all paths works and the funny thing is if use Zeiss "adjustment and check" program this error doesn't pop up. We've created our own PiWeb template, only thing changed is the header everything else is untouched. and on our other CMM's this template works without this error popping up. If i create a new program from scratch with the standard template this error also pops up and that leads back to what your writing that it have something to with the paths, but we can't located the bug? Link to comment https://qualityforum.zeiss.com/topic/27358-piweb-result-to-file-missing-1-protocolslog/#findComment-158478 Share on other sites More sharing options...
