[Ke...] Posted September 3 Share Posted September 3 No problems in getting the Default PiWeb Reporting, it pops up on the screen after end of program. But then PiWeb continues to read and after a while the below message pop up. We're running with Calypso 7.6.20 and PiWeb 8.4.23.0? Link to comment https://qualityforum.zeiss.com/topic/27358-piweb-result-to-file-missing-1-protocolslog/ Share on other sites More sharing options...
[Ma...] Posted October 12 Share Posted October 12 Hello Kenneth, sorry for the late reply, do you save the PiWeb PDF automatically? If yes, does it work? Within the inspection plan folder is the mentioned protocols.log, if there is an error it should be visible there, maybe you can attach it here for a closer look. Best Regards Marcel Link to comment https://qualityforum.zeiss.com/topic/27358-piweb-result-to-file-missing-1-protocolslog/#findComment-156778 Share on other sites More sharing options...
[Ke...] Posted 3 hours ago Author Share Posted 3 hours ago Hi Marcel, Now i'm the one to reply late ☺ But many thanks for the feedback. We're still having the problem. We're not saving our reports from PiWeb, we upload our results as table files *.fet, *.chr, *hdr. These table files are grapped by our internal system. We only use Piweb during creation of our programs. This error only comes when we create new programs, if I run the "tactile_optical_adjustment_and_check_lin_V4.1_C7.4" from Zeiss, the report runs fine without any errors. I work with OI543 with RT-table and dotscan from 2024. The inserted clip below is from the inspection plan and as you wrote the error is listed in this file. Maybe a setting somewhere that needs a minor adjustment? Link to comment https://qualityforum.zeiss.com/topic/27358-piweb-result-to-file-missing-1-protocolslog/#findComment-158082 Share on other sites More sharing options...
