[Pa...] Posted September 3 Share Posted September 3 Hi everyone! I'm having trouble with my hawk2, it keeps loosing the connection to the pc. It happens everytime I use it, sometimes I can just reconnect the scanner and keep going, but most of the times I have to restart the pc to get it working. I can be in the middle of scanning a part and then it just loses the connection and I get a Error MFG-0011 when I cancel the work. Have anyone else had these types of problems with their hawk2? I've been in contact with my local supplier and Zeiss-support about it when the problem started. Link to comment https://qualityforum.zeiss.com/topic/27362-problems-with-t-scan-hawk2/ Share on other sites More sharing options...
[Jo...] Posted September 3 Share Posted September 3 (edited) I had seemingly similar problems with other systems (non metroligy) with cheap and or faulty cabel. Does it only happen when you use the scanner? Maybe a semi-faulty cable leads to data loss everytime you need bandwith to transfer the measurement data. Edited September 3 Link to comment https://qualityforum.zeiss.com/topic/27362-problems-with-t-scan-hawk2/#findComment-155258 Share on other sites More sharing options...
[Pa...] Posted September 4 Author Share Posted September 4 No, it happens when I just have it laying on the desk as well. Just as I wrote that I got the disconnect and connect sounds for the USB. The cable between the scanner and the hub is brand new and I've changed the cable betweem the hub and the PC to a certified 20GB/s 240W USB-C cable just to be sure. Link to comment https://qualityforum.zeiss.com/topic/27362-problems-with-t-scan-hawk2/#findComment-155278 Share on other sites More sharing options...
[Im...] Posted November 16 Share Posted November 16 It happen with me as well with my T-Scan Hawk 2 , i just tried to keep the main cable connection stable with minimum movment around it without any stretch around it. Unfortunately there is no any proper solution its just a work around. Link to comment https://qualityforum.zeiss.com/topic/27362-problems-with-t-scan-hawk2/#findComment-158314 Share on other sites More sharing options...
[No...] Posted November 19 Share Posted November 19 It might be the cable. We have similar errors frequently with an ATOS Capsule that uses a copper cable connection (the newer ones use glass fiber). We also exchanged the cable but it brought only partial improvement. Another possible cause if you use the scanner with a laptop connected to a docking station: Many modern high power docking stations have problems maintaining proper operation of peripheral devices after the PC wakes up from sleep. Frequent disconnect/reconnect events of all sorts of USB devices are a common symptom of such an issue. Link to comment https://qualityforum.zeiss.com/topic/27362-problems-with-t-scan-hawk2/#findComment-158454 Share on other sites More sharing options...
