[Jo...] Posted September 10 Share Posted September 10 Just a few questions on measurement force. Appreciate the insight! How many lbs of force does the probe place on the part when it's measuring? Is it the calibration force? 200mN is the default measuring force for probe qual. Does the force change with scanning vs single point? Does the force change when scanning into the probe stem vs. perpendicular to the probe stem? Link to comment https://qualityforum.zeiss.com/topic/27402-scanning-measuring-force/ Share on other sites More sharing options...
[Ma...] Posted September 10 Share Posted September 10 With active head it should keep pretty close to set probing force even for scanning. I am not familiar with us, but i read that like 20 grams of force. It should be 10N = 1kg so 10:1 ratio Usually it's default probing force is stored with calibration - you are setting that before calibrating. 1 Link to comment https://qualityforum.zeiss.com/topic/27402-scanning-measuring-force/#findComment-155476 Share on other sites More sharing options...
[Jo...] Posted September 21 Share Posted September 21 I wish Zeiss provided more guidance for this. It is very time consuming to experimentally derive, and there is precious little documentation that covers the effects of changing probing force. Link to comment https://qualityforum.zeiss.com/topic/27402-scanning-measuring-force/#findComment-155875 Share on other sites More sharing options...
