[Ai...] Posted September 10 Share Posted September 10 I am trying to export the data from multiple CMM runs into the same excel file. I am able to export the data from one run into the default Calypso excel sheet, but I want to have more data than the default sheet has. I would like to include columns to list the dimension type (linear distance, diameter, etc) and mold cavity number. I have an excel template that we currently fill out manually, but I want to automate the process. On our printouts, the dimension type for each characteristic and the cavity number are reported, so I figure that Calypso has some way of exporting this data to an excel sheet. Any help is appreciated, thanks! Link to comment https://qualityforum.zeiss.com/topic/27406-exporting-cmm-data-to-excel-adding-more-columns/ Share on other sites More sharing options...
[Ch...] Posted September 10 Share Posted September 10 I know you can do this all in Calypso, especially using PCM; But that's not what I do. I highly recommend using the .chr and .hdr table files. And then using a Python script or something. The .chr and .hdr tables files have everything you need in it already. Python could combine as many files as you want into the same file. Don't be intimidated writing Python scripts. With AI, everyone is a programmer now. 2 Link to comment https://qualityforum.zeiss.com/topic/27406-exporting-cmm-data-to-excel-adding-more-columns/#findComment-155490 Share on other sites More sharing options...
[Jo...] Posted September 17 Share Posted September 17 Say what you will about AI, but it is absolutely fantastic at spitting out python to deal with folders full of excel files. It has been a game changer (And I already was a python programmer!) Link to comment https://qualityforum.zeiss.com/topic/27406-exporting-cmm-data-to-excel-adding-more-columns/#findComment-155757 Share on other sites More sharing options...
[Lu...] Posted September 18 Share Posted September 18 (edited) anyone have a example or a phython script that can be shared? Edited September 18 Link to comment https://qualityforum.zeiss.com/topic/27406-exporting-cmm-data-to-excel-adding-more-columns/#findComment-155807 Share on other sites More sharing options...
