[is...] Posted September 11 Share Posted September 11 Hi All, I have a stylus system with 7 styli's that cannot be calibrated in one sphere orientation setting. First setting for calibration of some styli's then second setting for the rest. How can I put something like a programmable stop for me to be able to turn the sphere for the second orientation before the masterprobe runs again for the second time in the new sphere location? Thanks in advance. Link to comment https://qualityforum.zeiss.com/topic/27418-programmable-stop-in-probe-calibration/ Share on other sites More sharing options...
[Lu...] Posted September 11 Share Posted September 11 To run that on CNC only will be hard because u need to change sphere position and remesure with master probe again, the better solution in my oppinion is to put the reference sphere in vertical position with this angle i dont use the 4 positions that you can shoose i manually put the angle and use the sphere in vertical position Link to comment https://qualityforum.zeiss.com/topic/27418-programmable-stop-in-probe-calibration/#findComment-155566 Share on other sites More sharing options...
[Ra...] Posted September 11 Share Posted September 11 Do you have PCM? Link to comment https://qualityforum.zeiss.com/topic/27418-programmable-stop-in-probe-calibration/#findComment-155568 Share on other sites More sharing options...
[is...] Posted September 11 Author Share Posted September 11 (edited) Yes, I do have PCM, but not quite advance user yet. If you could share some script , that would be great. thanks. Edited September 11 Link to comment https://qualityforum.zeiss.com/topic/27418-programmable-stop-in-probe-calibration/#findComment-155572 Share on other sites More sharing options...
[is...] Posted September 11 Author Share Posted September 11 Please sign in to view this quote. This wont work with my stylus system configuration as I have +Z styli. Link to comment https://qualityforum.zeiss.com/topic/27418-programmable-stop-in-probe-calibration/#findComment-155576 Share on other sites More sharing options...
[Ra...] Posted September 11 Share Posted September 11 In the pre-settings of the master probe sphere2 characteristic, put something in like: message("Change Reference Sphere To New Orientation") I believe the program halts until you hit "OK" 3 Link to comment https://qualityforum.zeiss.com/topic/27418-programmable-stop-in-probe-calibration/#findComment-155578 Share on other sites More sharing options...
[is...] Posted September 11 Author Share Posted September 11 This is what I came up, and it works. will try yours Randawgg too. Initialize switch=0 in the program pre-settings. Then some coding in the second sphere location in characteristics pre-settings. 1 Link to comment https://qualityforum.zeiss.com/topic/27418-programmable-stop-in-probe-calibration/#findComment-155582 Share on other sites More sharing options...
[is...] Posted September 11 Author Share Posted September 11 Please sign in to view this quote. This definitely works too, and much simpler. Thanks. Link to comment https://qualityforum.zeiss.com/topic/27418-programmable-stop-in-probe-calibration/#findComment-155586 Share on other sites More sharing options...
