[is...] Posted 1 hour ago Share Posted 1 hour ago Hi All, I have a stylus system with 7 styli's that cannot be calibrated in one sphere orientation setting. First setting for calibration of some styli's then second setting for the rest. How can I put something like a programmable stop for me to be able to turn the sphere for the second orientation before the masterprobe runs again for the second time in the new sphere location? Thanks in advance. Link to comment Share on other sites More sharing options...
[Lu...] Posted 56 minutes ago Share Posted 56 minutes ago To run that on CNC only will be hard because u need to change sphere position and remesure with master probe again, the better solution in my oppinion is to put the reference sphere in vertical position with this angle i dont use the 4 positions that you can shoose i manually put the angle and use the sphere in vertical position Link to comment Share on other sites More sharing options...
[Ra...] Posted 56 minutes ago Share Posted 56 minutes ago Do you have PCM? Link to comment Share on other sites More sharing options...
[is...] Posted 46 minutes ago Author Share Posted 46 minutes ago (edited) Yes, I do have PCM, but not quite advance user yet. If you could share some script , that would be great. thanks. Edited 40 minutes ago Link to comment Share on other sites More sharing options...
