'All Positive Results' on the report...?
Working with Calypso version 7.8 2025, I have a question on reporting only positive results. The question may seem a little odd since we all would like to see positive results for EVERYTHING ๐Ÿ˜Š However, when it comes to the actual report of the data, I would like to see all positive results without any worry of displaying a negative sign. Is there a way to either enter a formula, or better yet, is there a place withing the PI web editor to check offย  - 'Positive Results Only' - ? Thanks in advance ๐Ÿ‘
https://qualityforum.zeiss.com/topic/27420-all-positive-results-on-the-report/
Hi,
there is no predefined filter that you can use instantly. In the Designer open the tab page structure, select the protocol element, switch to the data provider tab, select advanced filter and in the tab characteristic filter select "Characteristics within limit".
