[Ja...] Posted September 16 Share Posted September 16 I am measuring the flatness of several plains. The first two are the same size and have nearly the same measurement result. I go into the flatness characteristic, select 1500 error magnification and open Piweb form plot. The first one looks really good and in the bottom right-hand corner says 1500:1. Above that it says 1.000 minch. I think that's supposed to be inch. The second one also says 1500:1 but above that it says .100 minch and looks more severe. I think that's right, but the first one is wrong. It's like that no matter what I do. I have recreated the flatness characteristics and still the same thing depending on which plane I select. What could it be about that first plane? Both flatness results are within .0001" of each other. Link to comment https://qualityforum.zeiss.com/topic/27439-piweb-flatness/ Share on other sites More sharing options...
[Ja...] Posted September 16 Author Share Posted September 16 Here are some screen shots. Is there anything else you would like to see? Link to comment https://qualityforum.zeiss.com/topic/27439-piweb-flatness/#findComment-155725 Share on other sites More sharing options...
[Ri...] Posted September 18 Share Posted September 18 (edited) I would look at zoom level in the CAD Evaluation. 0.100 is ten times 1.000 Edited September 18 Link to comment https://qualityforum.zeiss.com/topic/27439-piweb-flatness/#findComment-155811 Share on other sites More sharing options...
[Ja...] Posted September 21 Author Share Posted September 21 Please sign in to view this quote. Zoom Level? Do you mean magnification? Isn't that the same for whatever character you select? I don't see anything that's not the same when I select the different characteristics. The curve magnification is the same when I select different features too. Link to comment https://qualityforum.zeiss.com/topic/27439-piweb-flatness/#findComment-155891 Share on other sites More sharing options...
[Ri...] Posted September 22 Share Posted September 22 Please sign in to view this quote. Yes, magnification. oops Link to comment https://qualityforum.zeiss.com/topic/27439-piweb-flatness/#findComment-155949 Share on other sites More sharing options...
