[Cr...] Posted September 16 Share Posted September 16 On a GD&T Engine position when using MMC and MMR on the feature and datum it reports the diameters of the feature and datum under the position result in the report. Is there a way to report the position value only? Turning additional report off doesn't work for this. Thank you Link to comment https://qualityforum.zeiss.com/topic/27441-gdt-engine-position-question/ Share on other sites More sharing options...
[Ca...] Posted September 16 Share Posted September 16 I did a little testing on my own seat of CALYPSO as well as a review of some development notes, and it appears this was simply be something that changed with newer versions/service packs. In 2024 (and as best I can tell, possibly some early SP's of 2025), the diameter for material modifier calculations was included in the report, and I don't see an easy way to disable this. As of (at least) 8.0.16, those diameters are no longer reported. 1 Link to comment https://qualityforum.zeiss.com/topic/27441-gdt-engine-position-question/#findComment-155727 Share on other sites More sharing options...
[Ma...] Posted September 17 Share Posted September 17 Can you mark the diameters? In Multi Report button there is a button on the top right to mark characteristics. Then when you mark them you need to check the box that says "Hide (Selected characteristics are not displayed)" Which is also in the multi report window. I don't know if that fixes this issue but it does exclude things from the report. Link to comment https://qualityforum.zeiss.com/topic/27441-gdt-engine-position-question/#findComment-155767 Share on other sites More sharing options...
[Cr...] Posted September 17 Author Share Posted September 17 I believe these diameters are being pulled from within the GD&T engine position characteristic and there is no option to mark those diameters Link to comment https://qualityforum.zeiss.com/topic/27441-gdt-engine-position-question/#findComment-155771 Share on other sites More sharing options...
[Pa...] Posted September 18 Share Posted September 18 OK I'm hoping someone else jumps in here because I don't remember the whole thing: This chunk of code {^((?!\.\(M|L\)|\^Diameter For).)*$} gets pasted into the piweb designer. I can't remember exactly what to do with it to make it work but it does remove those lines (as well as MMC / LMC lines that everybody hates). 1 Link to comment https://qualityforum.zeiss.com/topic/27441-gdt-engine-position-question/#findComment-155819 Share on other sites More sharing options...
[Ma...] Posted September 18 Share Posted September 18 Please sign in to view this username. Are you sure this formula is correct? This "^" means beginning of text and "$" means end of text - i don't think using it twice is correct. Or what is your goal and what it is doing and should not? This is some sort of regex, so you can try some online testers for that - perhaps some will fit into PiWeb usage. Link to comment https://qualityforum.zeiss.com/topic/27441-gdt-engine-position-question/#findComment-155829 Share on other sites More sharing options...
