GD&T Engine position question
On a GD&T Engine position when using MMC and MMR on the feature and datum it reports the diameters of the feature and datum under the position result in the report. Is there a way to report the position value only?
Turning additional report off doesn't work for this.
Thank you
I did a little testing on my own seat of CALYPSO as well as a review of some development notes, and it appears this was simply be something that changed with newer versions/service packs. In 2024 (and as best I can tell, possibly some early SP's of 2025), the diameter for material modifier calculations was included in the report, and I don't see an easy way to disable this. As of (at least) 8.0.16, those diameters are no longer reported.
  • Thank you! 1
Can you mark the diameters? In Multi Report button there is a button on the top right to mark characteristics. Then when you mark them you need to check the box that says "Hide (Selected characteristics are not displayed)" Which is also in the multi report window. I don't know if that fixes this issue but it does exclude things from the report.
I believe these diameters are being pulled from within the GD&T engine position characteristic and there is no option to mark those diameters
