[Ma...] Posted 8 hours ago Share Posted 8 hours ago Hello, Does anybody know any solution to make a probe follow the path without touching the material? I would like to have a helix path around an imaginary sphere (like image below) but I can't create Sphere with strategy "Helix Path", because machine is looking for a material and it ends up stopping the "measurement". The only way of making it work is to create a Point with strategy "CMM position" and formula for X, Y and Z, but machine is moving in "step-mode" (achieve first point and stop, achieve next point and stop) instead of smooth, continuous motion. Link to comment Share on other sites More sharing options...
[Da...] Posted 5 hours ago Share Posted 5 hours ago If I remember correctly, this can only be done with the option "FlyScan", which used to be available only for the VAST XT heads, but should now be also available for the XXT head, but I'm not 100 % sure. And even with FlyScan, I doubt that it would work with helical paths. Link to comment Share on other sites More sharing options...
[Ma...] Posted 4 hours ago Author Share Posted 4 hours ago Please sign in to view this username. thanks, I tried that also, but it still needs first point to probe and while scanning stylus won't drop down. Link to comment Share on other sites More sharing options...
[Ma...] Posted 2 hours ago Share Posted 2 hours ago I may be reading this wrong, but why do you want to air scan a feature that isn't there? Link to comment Share on other sites More sharing options...
[Br...] Posted 2 hours ago Share Posted 2 hours ago Matt, What is the purpose of scanning in mid air? Link to comment Share on other sites More sharing options...
[No...] Posted 1 hour ago Share Posted 1 hour ago (edited) I think there's no way to do this with normal Calypso, although the controller itself would of course be capable of moving the CMM along a helix path when receiving the proper commands. May I ask why you need this? Edited 1 hour ago Link to comment Share on other sites More sharing options...
