[Mi...] Posted September 22 Share Posted September 22 I'm trying to see if CBA is running and what mode its in to determine if a program will need operator inputs or not. I see that there is facsIsActive but my group is using CBA not FACS. If anyone has found a workaround for this it would be greatly appreciated Link to comment https://qualityforum.zeiss.com/topic/27469-a-way-to-check-if-calypso-basic-automation-is-runningis-in-automation-or-manual-mode/ Share on other sites More sharing options...
[Ra...] Posted September 22 Share Posted September 22 Not sure off hand, but does CBA use the AAI interface? If so: getRunMode("aai") will return true or false. 1 Link to comment https://qualityforum.zeiss.com/topic/27469-a-way-to-check-if-calypso-basic-automation-is-runningis-in-automation-or-manual-mode/#findComment-155983 Share on other sites More sharing options...
[Pe...] Posted September 25 Share Posted September 25 We use CBA not FACS, and facsIsActive() still works in our projects for this purpose. Have you tried it? 1 Link to comment https://qualityforum.zeiss.com/topic/27469-a-way-to-check-if-calypso-basic-automation-is-runningis-in-automation-or-manual-mode/#findComment-156123 Share on other sites More sharing options...
