Sub-values from a true position characteristic with PCM
Hi All,
How do you pull the sub-values from a true position characteristic with PCM?
I have a true position of a Ø (-H-) to a datum scheme (-A-B-C-), and it reports the calculated value. I need to report the correction values for pulling the true position in spec.
I know that you can enable an additional printout to get these values, but I would prefer to pull this into a standalone characteristic (Result element) using PCM.
When I attempt to cheat the software with "getActual("-H- Position1").y" I receive the following error.
Any help is appreciated!
