[Si...] Posted September 24 Share Posted September 24 Hi, this is more of a continued post from my last... Almost every time now with a full start up I get the CMM data not found error. In the past it was as simple as manually moving the machine to Center and rerunning the homing. Or somehow a smudge on the Z scale. This latest error I couldn't get it to home, so I manually moved the machine as close to the Machine Home and then ran the Homing process. It worked. (The machine travels 75% in Y and once the X travels to the left, it limits out) However, now every single program, Hundreds of them, are off. The machine tries to find them always off in the -X direction and I have to align the Base Alignments. I have read that the error of the CMM data is a possible Control Box being faulty and since this error happens Every..single..full start up now... Is that it? Additionally, at random The machine will have some sort of connection issue and just stop running. Most times this happens at a Probe change. So question 1, How does the Base Alignments shift in every program? Question 2, Is it possibly the control box (joystick box) is faulty. I currently have Calypso 2024. I am trying to narrow it down because its expensive to get a tech to come here if its something I may be overlooking or easily fix myself. Thanks. Link to comment https://qualityforum.zeiss.com/topic/27489-all-base-alignments-movedafter-having-homing-issues-no-cmm-data-found/ Share on other sites More sharing options...
[Ab...] Posted September 24 Share Posted September 24 (edited) Hello There is Knowledge base article that will give you step by step instructions on how to fix this error https://portal.zeiss.com/knowledge-base?id=1475168 Edited September 24 Link to comment https://qualityforum.zeiss.com/topic/27489-all-base-alignments-movedafter-having-homing-issues-no-cmm-data-found/#findComment-156085 Share on other sites More sharing options...
[Si...] Posted September 24 Author Share Posted September 24 Yes this is what I used. So your saying I should try rehoming again? Im talking about the base alignments moving and not the Homing issue. I think its a box fault problem. Link to comment https://qualityforum.zeiss.com/topic/27489-all-base-alignments-movedafter-having-homing-issues-no-cmm-data-found/#findComment-156087 Share on other sites More sharing options...
[No...] Posted September 25 Share Posted September 25 (edited) Please sign in to view this quote. If all your base alignments are shifted by the same amount and direction, you probably have a problem with the CMM reliably detecting its end switches while homing. This can have several reasons, one of them is indeed the controller being faulty. On our old Contura (2001) the end switches were magnets embedded in the ends of the scales and at one time we also had shifted alignments. It turned out that the distance between the magnets and the sensor detecting the magnet's position was too large, so a tech had to readjust it. You see, there are many possible causes for the same error. I don't know how this is connected to Calypso reporting missing CMM data, but all the symptoms you describe together point to a severe hardware problem in my opinion. Edited September 25 Link to comment https://qualityforum.zeiss.com/topic/27489-all-base-alignments-movedafter-having-homing-issues-no-cmm-data-found/#findComment-156107 Share on other sites More sharing options...
[Si...] Posted September 28 Author Share Posted September 28 Thanks. This helps, Its only during Homing where it limits out. To fix it I keep the machine now cloe to the home and at 10mm speed vs full. I will have a tech come out. The CMM data not found is because of a homing issue. Link to comment https://qualityforum.zeiss.com/topic/27489-all-base-alignments-movedafter-having-homing-issues-no-cmm-data-found/#findComment-156183 Share on other sites More sharing options...
