[Ja...] Posted September 25 Share Posted September 25 (edited) I have noticed that if I have the Speed set to 300 in the program, it will occasionally error out, and kick off the drives. If I set it at 200 or 160, its fine. I have also noticed this happening during probe qualifications (List Qualification). If I turn the speed control knob to 75%, it runs fine. Once i go back to 100%, it will alarm out every now and then. I have cleaned all the ways with lint free cloth and 99% isopropyl alcohol, and the clothes are coming off fairly clean. ( i do this every other day). Is there a global setting I can change to keep the maximum travel speed to 250 or less? Edited September 25 Link to comment https://qualityforum.zeiss.com/topic/27503-drives-shutting-off-during-movement-between-measurements/ Share on other sites More sharing options...
[Ze...] Posted September 25 Share Posted September 25 Maybe it's an air pressure issue? Link to comment https://qualityforum.zeiss.com/topic/27503-drives-shutting-off-during-movement-between-measurements/#findComment-156129 Share on other sites More sharing options...
[Ja...] Posted September 25 Author Share Posted September 25 I thought that as well, and I forgot to mention that I verified the air pressure only dropped to 4.98 bar when moving. Normally it sits between 5.00 and 5.04 bar. Link to comment https://qualityforum.zeiss.com/topic/27503-drives-shutting-off-during-movement-between-measurements/#findComment-156131 Share on other sites More sharing options...
[Lu...] Posted September 25 Share Posted September 25 i had issues with that the zeiss techinician told me to ajust at 5.05 max 5.1 Bars at 5.05 i have no issues in our new brand contura Link to comment https://qualityforum.zeiss.com/topic/27503-drives-shutting-off-during-movement-between-measurements/#findComment-156135 Share on other sites More sharing options...
[Ja...] Posted September 25 Share Posted September 25 As far as I know, the cut off pressure is 5 bar for Contura. So even if it drops to 4.99 or below momentarily, the drives will turn off. We had similar issue where it would shut off at lower speeds even. Zeiss tech told me the same thing as Luis and I have not had any issues after the adjustment. Link to comment https://qualityforum.zeiss.com/topic/27503-drives-shutting-off-during-movement-between-measurements/#findComment-156147 Share on other sites More sharing options...
[Ri...] Posted September 26 Share Posted September 26 Please sign in to view this quote. I recently had this similar issue on a Contura 2014, in my case somehow the air pressure became low (4.9), we bumped it back to 5.0 and it hasn't happened since. Link to comment https://qualityforum.zeiss.com/topic/27503-drives-shutting-off-during-movement-between-measurements/#findComment-156153 Share on other sites More sharing options...
[No...] Posted September 28 Share Posted September 28 (edited) Apart from air pressure the symptoms point to a lag issue. If the CMM starts moving with high acceleration and the belt (or whatever drives the axis) slips slightly, you get a difference between the distance the axis should have travelled and how far it actually moved according to the scales. This difference is constantly monitored by the controller, and if it exceeds a certain amount, the drives are shut off. Edited September 28 Link to comment https://qualityforum.zeiss.com/topic/27503-drives-shutting-off-during-movement-between-measurements/#findComment-156167 Share on other sites More sharing options...
[Ch...] Posted September 28 Share Posted September 28 Like Norbert, I’m of the opinion that the problem stems from the drive mechanism. Perhaps try cleaning the metal band with alcohol. If the roller has shifted, the drive is faulty. Zeiss needs to come and take a look.🙄 Link to comment https://qualityforum.zeiss.com/topic/27503-drives-shutting-off-during-movement-between-measurements/#findComment-156173 Share on other sites More sharing options...
[Sv...] Posted September 28 Share Posted September 28 The air bearing on the other side of the gantry may also be defective. Link to comment https://qualityforum.zeiss.com/topic/27503-drives-shutting-off-during-movement-between-measurements/#findComment-156175 Share on other sites More sharing options...
[Ja...] Posted October 1 Author Share Posted October 1 (edited) I increased the regulator on the CMM to an air pressure of 5.05 and that seems to have corrected the issue. I also increased the regulator coming out of the air dryer ( shop air > air/oil separator combo filter > dryer > hard air line > air/oil separator combo > CMM) to 7.0 to ensure I don't lose air pressure when both CMM's are running. Edited October 1 2 Link to comment https://qualityforum.zeiss.com/topic/27503-drives-shutting-off-during-movement-between-measurements/#findComment-156371 Share on other sites More sharing options...
