[ko...] Posted September 29 Share Posted September 29 (edited) Hello everyone. I am new to ZEISS INSPECT and I am not an expert, so I would appreciate your guidance with the following measurement problem. I need to measure two distances (marked in Yellow) from a Ø16.4 theoretical exact dimension (TED) circle, shown in green in the attached images. The adjacent blue profile is not conical; it is a toroidal surface. However, I cannot find an option in ZEISS INSPECT to construct or fit a torus, and the available construction appears to allow only a cone. My preferred strategy is to create a nominal cylinder with a diameter of 16.4 mm and then construct a circle from the intersection between this cylinder and the measured toroidal feature. As an alternative, I considered creating a section through the feature and using the intersection of that section with the Ø16.4 cylinder. Unfortunately, I have not been able to identify the appropriate ZEISS INSPECT functions for either method. As a temporary workaround, I created the circle on a fitted cone. This produces a result, but it is not geometrically correct because the actual feature is a torus. The cone fit may therefore shift the reference circle and affect the two distance results. Could you please advise on the correct workflow to: 1. calculate its intersection with the measured toroidal surface, or with a section derived from that surface; 2. construct a circle from the resulting intersection; and 3. use that circle as the reference for the two distance measurements? Edited September 29 Pictures Layout Improvement Link to comment https://qualityforum.zeiss.com/topic/27521-how-can-i-create-a-reference-circle-from-the-intersection-of-a-nominal-cylinder-and-a-toroidal-surface-in-zeiss-inspect/ Share on other sites More sharing options...
[Ma...] Posted September 29 Share Posted September 29 Well, this is not an easy job for beginner 🙂 I would suggest making a cylindrical section ( in Section menu ) - you will select axis and radius. Select area on mesh and it will make an section. Now select that section and make a circle from it ( fitting principle ) Now you need to obtain somehow other side of those dimensions. You can either use touch caliper or make there a fitting circle and intersection it with theoretical plane to obtain quadrant. Now you can measure as 2point distance. Link to comment https://qualityforum.zeiss.com/topic/27521-how-can-i-create-a-reference-circle-from-the-intersection-of-a-nominal-cylinder-and-a-toroidal-surface-in-zeiss-inspect/#findComment-156227 Share on other sites More sharing options...
