[Ri...] Posted September 29 Share Posted September 29 Does anyone know of an efficient way to Recall Feature Points from a Curve that has a Pattern on it? In my example, I have a group of (4) curves that has a 116x pattern on them. I need to then create a FreeForm Surface for each 4x group of curves - so essentially I need to create 116x FFS that pulls from the correct set of (4) curves. Any and all help is greatly appreciated. Link to comment Share on other sites More sharing options...
[Mi...] Posted September 30 Share Posted September 30 Hello Richard, I didn't fully understand what you're trying to achieve. Could you post a few pictures of your current setup and what you're aiming for? Link to comment Share on other sites More sharing options...
[Ri...] Posted September 30 Author Share Posted September 30 Please sign in to view this quote. Hi Michael, I am measuring a blisk. I'm limited to programming in Calypso 2023, so I cannot place patterns on a FreeForm Surface, so currently I'm programming it as 3d Curves that I will then recall feature points into a FreeForm Surface. Due to orientation and angles, I'm measuring it as (3) cross-sections, and (2) different angles, so in total it is (6) 3d Curves, per side, so in total there are (12) 3d Curves that make up one blade. I'm looking for an efficient way to correctly recall feature points from the (12) individual 3d Curves into their respective FreeForm Surface. So for the example above, I'd need to pull the points from 3D Curve - 1-1(1), 3D Curve - 1-2(1), 3D Curve - 1-3(1), 3D Curve - 2-1(1), 3D Curve - 2-2(1), 3D Curve - 2-3(1), 3D Curve - 3-1(1), 3D Curve - 3-2(1), 3D Curve - 3-3(1), 3D Curve - 4-1(1), 3D Curve - 4-2(1), 3D Curve - 4-3(1). And that is for just the first blade, there are 115 more to create. It's a lot of manual work that I'm trying to avoid if possible. Link to comment Share on other sites More sharing options...
[Ma...] Posted Friday at 11:44 AM Share Posted Friday at 11:44 AM Please sign in to view this username. I don't have FFS, but I assume you can use formula in recall feature points. I would use PCM to create a list with desired elements and recall that list using formula. You have to change a loop index in every element, but you can come up with some "automatic index extract" from name of element or something and you just copy paste that element x115 😄 nameOfElement = "Point" noOfElements = 4 noOfSections = 3 loop = 1 recallElementsList = "list(" for i = 1 to noOfElements for j = 1 to noOfSections recallElementsList = recallElementsList + qm() + nameOfElement + "_" + i + "_" + j + "(" + loop + ")" + qm() + "," next j next i recallElementsList = mid(recallElementsList,1,(len(recallElementsList) - 1))) recallElementsList = recallElementsList + ")" //display(recallElementsList) recallElementsList = getParameterNamed(recallElementsList) 2 1 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted Saturday at 04:21 PM Author Share Posted Saturday at 04:21 PM Please sign in to view this username. This is perfect! I didn't realize you could build a list like so to be used in such a way. Here is the complete code (I removed the sections to clean up the measurement plan), but this now has an automatic loop detection based upon the end number of the feature name. 🙂 nameOfElement = "3D Curve - " noOfElements = 4 featureName = getNominal().testPlanGeometry.identifier prefix = "Blisk - Free Form Surface - " loop = mid(featureName,len(prefix) + 1,len(featureName)) loop = val(loop) recallElementsList = "list(" for i = 1 to noOfElements recallElementsList = recallElementsList + qm() + nameOfElement + i + "(" + loop + ")" + qm() + "," next i recallElementsList = mid(recallElementsList,1,(len(recallElementsList) - 1)) recallElementsList = recallElementsList + ")" //display(featureName) //display(loop) //display(recallElementsList) recallElementsList = getParameterNamed(recallElementsList) If you want to keep from the list overwriting for every feature, you can use the following as well. nameOfElement = "3D Curve - " noOfElements = 4 featureName = getNominal().testPlanGeometry.identifier prefix = "Blisk - Free Form Surface - " loop = mid(featureName,len(prefix) + 1,len(featureName)) loop = val(loop) tempRecallList = "list(" for i = 1 to noOfElements tempRecallList = tempRecallList + qm() + nameOfElement + i + "(" + loop + ")" + qm() + "," next i tempRecallList = mid(tempRecallList,1,(len(tempRecallList) - 1)) tempRecallList = tempRecallList + ")" recallElementsList[loop] = getParameterNamed(tempRecallList) 2 Link to comment Share on other sites More sharing options...
