[Be...] Posted 6 hours ago Share Posted 6 hours ago Hi everyone, I could use some help here. I have a drawing that specifies an angularity check with an asymmetrical tolerance zone. How do I inspect this? I’ve already constructed the feature to be inspected and the datum. However, when I try to check the angularity, I can't set an asymmetrical tolerance—like you can for a surface profile, for example. Does this actually work for angularity, or do I need to inspect it differently? Thanks in advance for your help! Link to comment Share on other sites More sharing options...
[Jo...] Posted 5 hours ago Share Posted 5 hours ago (edited) Have you tried the option "projected tolerance Zone"? Have not used this myself, but looks like this would provide the function of an offset tolerance zone. Or not... Edited 5 hours ago Link to comment Share on other sites More sharing options...
[Ma...] Posted 5 hours ago Share Posted 5 hours ago This is nonsense callout. Same like flatness it's reporting distance from MIN to MAX point on plane defined by angle from datum. In this case it would be better to use perpendicularity - it's 90°. But you can not use assymetric tolerance. Link to comment Share on other sites More sharing options...
