Question about report
Hello all,
I'm a little confused about the report with the bar all the way on the right side. If you're looking at the values, it lists them left to right as "measured value, nominal value, +tol, -tol, deviation, and +/-".
I've always thought that the bar on the right side under "+/-" displayed it as a measurement of low tolerance (left side of bar) and high tolerance (right side of bar) with the centerline signifying nominal. A part ran the other day and when the report came out the measured value measured under nominal value (for example, nominal is 1.50 ±0.005 and the measured value was 1.4976). The value still measured within tolerance, but the green bar was to the right of the centerline under the "+/-" display. Can someone help explain to me why that might be? I always thought that if it measured below the nominal value then it would show to the left of the centerline? I measured the actual diameter that was out with a caliper, and it measured pretty much the same as the CMM.
I've attached a photo below of what I'm describing
This is the photo from the actual report. Measured value is less than nominal value
I would assume that the green bar should go to the left of the centerline? I may be looking at it wrong though
Edited
thats why you should give us more unfiltered info ...
this is all through your lens and that doesent seem to make sense 🙂
Screenshot the whole line with nominal tolerances actual and the graphical bar.
Never looked that hard at the scale, usually looking at deviation. Pulled up a report and noticed the first dimension graphic appears centered around the means even though it is above the means dimensionally. Maybe scaling because of the large tolerance on the dimension? Again, never paid much attention to the graphic, I believe it is intended as a graphical aid, but you piqued my curiosity.
