GTOOLS-0001 Error
Hello Mr. Smith,
the log just shows:
Please verify that the device is correctly connected and switched on.
11:59:33 shutdown (14.03.2023)
If everything is set up correctly (did you do help/systemanalysis/sensor? If yes, please share a screenshot)
please contact our hardware support.
Best regards,
Jens Braun
Hi Jens
Thank you for the reply, I have included the following screenshots
Sensor connects and scans when i revert back to Gom 2021
When i move back to Gom 2022 , I get the same info from the Analyse Sensor screen. But it will not connect and throws up the GTOOLS-0001 Error
Regards
Roger
