What is with all this Connect/Disconnect activity on both our Micuras?
I see a string of connect/disconnect activity on 10.05.26 between 9.44.03 am and 10.01.49 am, this is from one of the Micrua's, the other is similar.
See attached dat file (renamed to a txt file for uploading.
sm_events_10.06.26 550146.dat.txt
No idea what the cause is, but I see this once a month or so across all 6 of our machines, and it corresponds with a loss of connection to smart services, or at least a weird degraded connection where I get some live information but not all of it. Whenever this happens I will go out to the workstations and sign out of the active user account or just reboot entirely. There has to be something in the chain of services from tracer to CMM agent that falls over after a long period of time.
  • Like! 1
Hi Richard,
it could be another program trying to connect via the intranet network, normally CALYPSO should only show the local host (127.0.0.1) if its an internal application call, for example when you switch to GEAR Pro.
As
 mentioned, you should involve your IT department to take a closer look, even tho i dont think its an attack, but another software is trying to connect or at least scans the CALYPSO Ports.
A quick check would be to disconnect the LAN cable from the Intranet (if you programs are stored local), then this message should not appear anymore.
Best Regards
Marcel
All of the results are stored on the network at creation less some general information for Excel file creation which is local.
I will look into making the Drive a variable in PCM so I can swap it on the run in the future.
10.x.x.x are "non routeable private IP addresses"   It is 100% coming from inside your own IT infrastructure. (Similar to how 192.168.x.x is also non routable and popular for home routers)
Edited
  • Like! 1
