[Ri...] Posted yesterday at 11:07 AM Share Posted yesterday at 11:07 AM I see a string of connect/disconnect activity on 10.05.26 between 9.44.03 am and 10.01.49 am, this is from one of the Micrua's, the other is similar. Please sign in to view this quote. See attached dat file (renamed to a txt file for uploading. sm_events_10.06.26 550146.dat.txt Link to comment Share on other sites More sharing options...
[Th...] Posted yesterday at 03:54 PM Share Posted yesterday at 03:54 PM No idea what the cause is, but I see this once a month or so across all 6 of our machines, and it corresponds with a loss of connection to smart services, or at least a weird degraded connection where I get some live information but not all of it. Whenever this happens I will go out to the workstations and sign out of the active user account or just reboot entirely. There has to be something in the chain of services from tracer to CMM agent that falls over after a long period of time. 1 Link to comment Share on other sites More sharing options...
[Jo...] Posted 23 hours ago Share Posted 23 hours ago Are you directly connected between your computer and CMM? Did someone reboot the ethernet switch in between devices? Link to comment Share on other sites More sharing options...
[Da...] Posted 5 hours ago Share Posted 5 hours ago Your IT department needs to identify 10.3.17.71. It might be a cyberattack. Link to comment Share on other sites More sharing options...
[Ma...] Posted 5 hours ago Share Posted 5 hours ago Hi Richard, it could be another program trying to connect via the intranet network, normally CALYPSO should only show the local host (127.0.0.1) if its an internal application call, for example when you switch to GEAR Pro. As Please sign in to view this username. mentioned, you should involve your IT department to take a closer look, even tho i dont think its an attack, but another software is trying to connect or at least scans the CALYPSO Ports. A quick check would be to disconnect the LAN cable from the Intranet (if you programs are stored local), then this message should not appear anymore. Best Regards Marcel Link to comment Share on other sites More sharing options...
[Ri...] Posted 5 hours ago Author Share Posted 5 hours ago Please sign in to view this quote. All of the results are stored on the network at creation less some general information for Excel file creation which is local. I will look into making the Drive a variable in PCM so I can swap it on the run in the future. Link to comment Share on other sites More sharing options...
[Ri...] Posted 5 hours ago Author Share Posted 5 hours ago I have looked at all of our CMM's and this activity is on them all, it looks like a rolling time frame with different IPs (Similar to the original test posted) per CMM. Link to comment Share on other sites More sharing options...
[Ri...] Posted 3 hours ago Author Share Posted 3 hours ago Does Zeiss have a server in Kentucky where this type of activity could ariginate? Link to comment Share on other sites More sharing options...
