[Lu...] Posted October 6 Share Posted October 6 Hello, We recently had an issue with parts failing when using the Star Probe, but calibration would pass using the sphere. After investigating we found that the probe was slightly angled and not straight. We loosen the probe and rotated it until we felt it looked straight in XandY. Question : is there a way to check the physical alignment/straightness on this probe ?? Does a fixture exist or any regular maintenance recommended (other than the daily calibrations with spheres). Link to comment https://qualityforum.zeiss.com/topic/27597-star-probe-straightness-check/ Share on other sites More sharing options...
[No...] Posted October 7 Share Posted October 7 Zeiss offers a universal probe assembly aid called FixAssist, but in my opinion this is expensive luxury. I always adjusted my straight probes either through eyesight (by lining up - with one eye closed - the probe shaft with the edge of a magnetic chuck mounted on the granite) or with a simple "homebrew" fixture consisting of a milled probe plate holder and a vertical movable v-block in a sliding groove to center the tip. Here's a design draft: Link to comment https://qualityforum.zeiss.com/topic/27597-star-probe-straightness-check/#findComment-156613 Share on other sites More sharing options...
[Ri...] Posted October 7 Share Posted October 7 (edited) I use an indicator running it along the shaft of the Stylus and align the stylus to one of the axes (X or Y) within .001" per 1 inch of stroke. If you are using two or more styli in two or more axes, just indicate one of them. Otherwise, you will be chasing them all day. Edited October 7 Link to comment https://qualityforum.zeiss.com/topic/27597-star-probe-straightness-check/#findComment-156639 Share on other sites More sharing options...
[Ch...] Posted October 7 Share Posted October 7 Lucas, you can move the star probe parallel to the component and then check the gap to see whether it is parallel. Link to comment https://qualityforum.zeiss.com/topic/27597-star-probe-straightness-check/#findComment-156649 Share on other sites More sharing options...
[Ke...] Posted October 8 Share Posted October 8 When adjusting the stylus angle visually, use the longest possible stylus or extension. Adjusting with a stylus that is twice as long will halve the deviation. 2 Link to comment https://qualityforum.zeiss.com/topic/27597-star-probe-straightness-check/#findComment-156673 Share on other sites More sharing options...
[Da...] Posted October 8 Share Posted October 8 Not Really need to make probes. Link to comment https://qualityforum.zeiss.com/topic/27597-star-probe-straightness-check/#findComment-156685 Share on other sites More sharing options...
[Pa...] Posted November 9 Share Posted November 9 Please sign in to view this quote. We've got the FixAssist. It's amazing how often it can't help. Link to comment https://qualityforum.zeiss.com/topic/27597-star-probe-straightness-check/#findComment-158108 Share on other sites More sharing options...
[Ri...] Posted November 11 Share Posted November 11 Please sign in to view this quote. I tried using one once, it never really made the stylus near the capability, like when I indicate to .001" (previous post). Granted, not all stylus tips can be indicated to within .001" on any axis, the assembly allows too much variation. Link to comment https://qualityforum.zeiss.com/topic/27597-star-probe-straightness-check/#findComment-158160 Share on other sites More sharing options...
