[Ya...] Posted October 7 Share Posted October 7 Hallo zusammen, ich habe das Problem, dass ich eine Parallelität auswerten muss von einer Ebene mit der Toleranz "0,03/100" und dem Bezug zur Basisebene A. Unter Quindos konnte ich direkt die Bezugslänge einstellen. Die Option finde ich bei Calypso leider nicht, außer ich werte es mit Bohrungen aus. Vielen Dank für die Hilfe. Link to comment https://qualityforum.zeiss.com/topic/27601-parallelit%C3%A4t-bezugsl%C3%A4nge-angeben-bei-zwei-ebenen/ Share on other sites More sharing options...
[Ma...] Posted October 7 Share Posted October 7 I think there is no parallelism ref same as flatness ref, but you could make alignment from your datum, use that datum in controlled feature, then use flatness and constrain vector. Link to comment https://qualityforum.zeiss.com/topic/27601-parallelit%C3%A4t-bezugsl%C3%A4nge-angeben-bei-zwei-ebenen/#findComment-156619 Share on other sites More sharing options...
[Ya...] Posted October 8 Author Share Posted October 8 Thanks for the answer. I thought it has something to do with the new ISO and the GDT elements in Calypso. Because the older Quindos software had the exact feature implemented, to measure the parallelism between two flats for a specific length. Link to comment https://qualityforum.zeiss.com/topic/27601-parallelit%C3%A4t-bezugsl%C3%A4nge-angeben-bei-zwei-ebenen/#findComment-156693 Share on other sites More sharing options...
