Zeiss Inspect optical 3D 2026 - free version - recalculate function missing
Well free version should be without those functions.
You can not edit creation parameters, so this should apply even for this.
But i found there is polygonization with recalculation in Acuisition menu. This recalculation button should be in menu - if not, then you can not use that.
I believe in 2025 there is also missing this button.
Thank you for your reply!
Yes, I know for editing of creation parameters I need professional license.
But in free version, if I only change between pre-alignment and main alignment the software is not able to refresh calculated data automatically, that's why the function "recalculate project" would be necessary.
The recalculation function is not found either in the menu or as an icon under the menu bar.
Without this option I can not recommend anybody to use free version.
The "Free" version has 'automatic recalculation' turned on by default.  if your elements are visible and you switch alignments, they should recalculate automatically, if not they may have a broken dependency (?) - you can check the reason in the properties tab of the element. If its the latter, you can always re-create the check/element (you can not edit w free version). but that being said its extremely powerful free software, I only wish they'd get rid of the log in / license requirement. (like the good ol' GOM Inspect days).
Good luck, post more details if your struggling with something in particular.
In the future, this forum may be more appropriate & provide a quicker response:
https://qualityforum.zeiss.com/forum/20-general/
