Probes validation
I am trying to write a simplified PCM code to do the validate probe data.  I have one already just trying to cut it down and make it easier.  First step is to read all the data of a given probe to validate.  I have a list of probes from a text file that i loop through to validate, but i want to use:
//rad1=(getProbe("1",line[I]).diameter*25.4)
//rad2=(getProbe("2",line[I]).diameter*25.4)
//rad3=(getProbe("3",line[I]).diameter*25.4)
//rad4=(getProbe("4",line[I]).diameter*25.4)
//rad5=(getProbe("5",line[I]).diameter*25.4)
//std1=(getProbe("1",line[I]).stdProbeDev)
//std2=(getProbe("2",line[I]).stdProbeDev)
//std3=(getProbe("3",line[I]).stdProbeDev)
//std4=(getProbe("4",line[I]).stdProbeDev)
//std5=(getProbe("5",line[I]).stdProbeDev)
//px1=(getProbe("1",line[I]).probeVector.x)
//px2=(getProbe("2",line[I]).probeVector.x)
//px3=(getProbe("3",line[I]).probeVector.x)
//px4=(getProbe("4",line[I]).probeVector.x)
//px5=(getProbe("5",line[I]).probeVector.x)
//py1=(getProbe("1",line[I]).probeVector.y)
//py2=(getProbe("2",line[I]).probeVector.y)
//py3=(getProbe("3",line[I]).probeVector.y)
//py4=(getProbe("4",line[I]).probeVector.y)
//py5=(getProbe("5",line[I]).probeVector.y)
Problem is if the probe does not have the tip given, it will error.  I am trying to find PCM code to ONLY use the tips in a given probe cofiguration.  All I have found so far to do this is with the Active probe, but I am doing all this before the probes are active.
The way I am doing it right now is to have a running list of each probe and tips, and only evaluate certain ones... trying to get this simplified so that with new programmers in training, it will be less to update and make errors when a new configuration is made.
https://qualityforum.zeiss.com/topic/27632-probes-validation/
//systemCall("cmd.exe /c taskkill /IM notepad.exe /F")
// Constants
MAX_STYLI = 10
MAX_SELECT = 11
// Reference Sphere Diameter
Ref1Dia = baseSystem().machine.machineControl.sphereNormalObject.sphereRadius * 2
// Clear files
deleteFile(systemFile)
deleteFile(styliFile)
deleteFile(correctionFile)
// Stylus System selection (Sorted)
probeKeys = baseSystem().machine.machineAllProbeObjects.keys.asList
probeKeys.sort  // Alphabetical sort (ascending)
SS_List = "stylusSystem=inquireList(" + chr(34) + "Select Stylus System to Evaluate" + chr(34)
for i = 1 to probeKeys.size
    SS_List = SS_List + "," + chr(34) + getParameterNamed(probeKeys, i) + chr(34)
next i
SS_List = SS_List + ")"
addToFile(systemFile, SS_List)
runPCMFile(systemFile)
changeStylusSystem(stylusSystem)
// Gather active stylus tips
activeStylusTips = baseSystem().machine.machineProbeConfiguration.allProbes.values.asList
styli_List = ""
for i = 1 to activeStylusTips.size
	currentTip = getParameterNamed(activeStylusTips, i)
	styli_List = styli_List + currentTip.ident + cr() + currentTip.probeName + cr()
next i
addToFile(styliFile, styli_List)
// Read stylus tip list
styli_ListFile = readListFile(styliFile)
// Tip assignments
for i = 1 to 5
	tip_num = val(getParameterNamed(styli_ListFile, i * 2 - 1))
	tip_name = getParameterNamed(styli_ListFile, i * 2)
	if tip_num == 1
		tip1 = tip_name
		tip1num = 1
	endif
	if tip_num == 2
		tip2 = tip_name
		tip2num = 2
	endif
	if tip_num == 3
		tip3 = tip_name
		tip3num = 3
	endif
	if tip_num == 4
		tip4 = tip_name
		tip4num = 4
	endif
	if tip_num == 5
		tip5 = tip_name
		tip5num = 5
	endif
next i
// Initialize stylus array
for i = 1 to MAX_STYLI
	stylus[i] = i
	Styli[i] = 0
next i
stylus[MAX_SELECT] = "1-10"
for i = 1 to MAX_SELECT
	selectstylus[i] = "-"
next i
// Other initialization
TypCMM = ""
AR_stylus = getCFNames()
runMode = getRunID()
cncBreak = 0
l = 1
// Auto-run logic
CR2 = getParameterNamed(AR_stylus, 2)
CRX = "End"
if CR2 == "Activate" and runMode == "Detail"
	for m = 1 to 11
		selectstylus[m] = getParameterNamed(AR_stylus, m + 2)
		if selectstylus[m] == CRX
			selectstylus[m] = "-"
			m = 11
		else
			selectstylus[m] = val(selectstylus[m])
			Styli[selectstylus[m]] = 1
		endif
	next m
else
	selectCase runMode
	// Manual Detail Mode
	case runMode == "Detail"
		selectstylus[1] = inquireList("Please select the stylus you want to verify.", stylus[1], stylus[2], stylus[3], stylus[4], stylus[5], "cancel")
		if selectstylus[1] == "cancel"
			cncBreak()
		endif
		if selectstylus[1] == "1-10"
			for m = 1 to MAX_STYLI
				Styli[m] = 1
				selectstylus[m] = stylus[m]
			next m
			l = MAX_SELECT
		endif
		for s = 1 to MAX_STYLI
			if selectstylus[1] == stylus[s]
				stylus[s] = ""
				Styli[s] = 1
			endif
		next s
		m = 2
		for j = 1 to 10
			if cncBreak == 1
				j = 10
			else
				selectstylus[m] = inquireList("Please select the stylus you want to verify.", stylus[1], stylus[2], stylus[3], stylus[4], stylus[5], "ready", "cancel")
				if selectstylus[m] == "cancel"
					cncBreak()
					cncBreak = 1
					j = 10
				endif
				if selectstylus[m] == ""
					message("Please select a stylus, select 'ready' or select 'cancel'")
					j = j - 1
					m = m - 1
				endif
				if selectstylus[m] == "ready"
					j = 10
				endif
					if selectstylus[m] == stylus[s]
						Styli[s] = 1
						stylus[s] = ""
					endif
				next s
				m = m + 1
			endif
		next j
	// Run Complete Mode
	case runMode == "Run Complete"
			Styli[m] = 1
		next m
		l = MAX_SELECT
	// Complete Mode
	case runMode == "Complete"
			Styli[m] = 1
		next m
		l = MAX_SELECT
	endSelect
endif
// Disable unassigned tips
if tip1num <> 1
	Styli[1] = 0
endif
if tip2num <> 2
	Styli[2] = 0
endif
if tip3num <> 3
	Styli[3] = 0
endif
if tip4num <> 4
	Styli[4] = 0
endif
if tip5num <> 5
	Styli[5] = 0
endif
Above is the code for a Stylus Verification/Adjustment measurement plan that I built to work for standard Star Probes. It will prompt you to select the stylus system that you want to verify/adjust.
I believe that the only way (other than some hidden command that is known to few) to access the styli list for a particular stylus system is to have it active first.
Obviously you do not need all of my code, but there are pieces of it that will work well for you. Mainly these parts:
next i
styli_List = ""
next i
This will build a list of all of the Stylus Systems available, prompt you to select the stylus system that you want to validate, change to that stylus system, and finally build a list of the styli available on that stylus system.
  • Thank you! 1
https://qualityforum.zeiss.com/topic/27632-probes-validation/#findComment-156770
Oh, and you can handle the issue of only selecting the ones that exist with if statements in the PCM code, and putting Conditions on the Characteristic (this will force you to run from the Characteristics side though).
I took this idea below from the O-Inspect ToA measurement plan - works great!
// Tip assignments
for i = 1 to 5
	if tip_num == 1
		tip1 = tip_name
		tip1num = 1
	endif
	if tip_num == 2
		tip2 = tip_name
		tip2num = 2
	endif
	if tip_num == 3
		tip3 = tip_name
		tip3num = 3
	endif
	if tip_num == 4
		tip4 = tip_name
		tip4num = 4
	endif
	if tip_num == 5
		tip5 = tip_name
		tip5num = 5
	endif
next i
	stylus[i] = i
	Styli[i] = 0
next i
next i
TypCMM = ""
cncBreak = 0
l = 1
// Auto-run logic
CRX = "End"
	for m = 1 to 11
			m = 11
		else
		endif
	next m
else
	selectCase runMode
			cncBreak()
		endif
				Styli[m] = 1
			next m
			l = MAX_SELECT
		endif
				stylus[s] = ""
				Styli[s] = 1
			endif
		next s
		m = 2
		for j = 1 to 10
			if cncBreak == 1
				j = 10
			else
					cncBreak()
					cncBreak = 1
					j = 10
				endif
					j = j - 1
					m = m - 1
				endif
					j = 10
				endif
						Styli[s] = 1
						stylus[s] = ""
					endif
				next s
				m = m + 1
			endif
		next j
			Styli[m] = 1
		next m
		l = MAX_SELECT
	// Complete Mode
			Styli[m] = 1
		next m
		l = MAX_SELECT
	endSelect
endif
if tip1num <> 1
	Styli[1] = 0
endif
if tip2num <> 2
	Styli[2] = 0
endif
if tip3num <> 3
	Styli[3] = 0
endif
if tip4num <> 4
	Styli[4] = 0
endif
if tip5num <> 5
	Styli[5] = 0
endif
If the tipnum does not equal 1, then the Styli[n] is set to 0.
The condition on the characteristic is looking for that status of Styli[n] to equal 1; it will only run that characteristic if it equals 1.
  • Thank you! 1
https://qualityforum.zeiss.com/topic/27632-probes-validation/#findComment-156772
