[Ri...] Posted October 12 Share Posted October 12 How can I determine when a user change has occurred in Calypso, particularly when in AutoRun. Is there a log file of user changes or some other file I can look at? Link to comment https://qualityforum.zeiss.com/topic/27640-user-login-change/ Share on other sites More sharing options...
[Ma...] Posted October 12 Share Posted October 12 I can not find anything which would be like a log. Perhaps there is a file rewriting it's content which could contain user change, but i doubt that. Link to comment https://qualityforum.zeiss.com/topic/27640-user-login-change/#findComment-156810 Share on other sites More sharing options...
[Ri...] Posted October 12 Author Share Posted October 12 I couldn't find anything either. If this is not logged, it should be. I think I have an issue where one or more users are logging in and out of Master and messing around with settings. I am changing the master user pword, again, problem is, a savvy user would know how to find the master pword and change it. I know I can change the master pword to what I want and then change it back to what it was. Link to comment https://qualityforum.zeiss.com/topic/27640-user-login-change/#findComment-156812 Share on other sites More sharing options...
[No...] Posted October 12 Share Posted October 12 Don't you think a user savvy enough to know how to change the pw would also mess with the log if one existed? 🤔 Like I always said: Calypso's security is a stale joke. 2 Link to comment https://qualityforum.zeiss.com/topic/27640-user-login-change/#findComment-156814 Share on other sites More sharing options...
[Sv...] Posted October 13 Share Posted October 13 I have configured Calypso so that AutoRun opens automatically upon startup and the production user logs in. This user has just enough privileges to launch programs; they aren't even allowed to move an image. This works great for us. Furthermore, the production user cannot exit AutoRun to open Calypso. Link to comment https://qualityforum.zeiss.com/topic/27640-user-login-change/#findComment-156830 Share on other sites More sharing options...
[No...] Posted October 13 Share Posted October 13 Even then it is possible to circumvent all those measures and become Master. Security is on - hmmm - Windows 3.1 level? 😄 Link to comment https://qualityforum.zeiss.com/topic/27640-user-login-change/#findComment-156838 Share on other sites More sharing options...
[Ma...] Posted October 13 Share Posted October 13 Please sign in to view this username. Problem is, that you can change user logined in even from autorun mode. Please sign in to view this username. I found one file, in which is stored actual user - so read it constantly and you can log it. Here is my git, where is something to this matter https://github.com/justyand/CalypsoAPI This file is here "c:\Users\Public\Documents\Zeiss\cmmObserver\observerFile.txt" and "operid" is changing 1 Link to comment https://qualityforum.zeiss.com/topic/27640-user-login-change/#findComment-156840 Share on other sites More sharing options...
[Ri...] Posted October 13 Author Share Posted October 13 It's a start, I appreciate the effort and time involved. Link to comment https://qualityforum.zeiss.com/topic/27640-user-login-change/#findComment-156848 Share on other sites More sharing options...
[Ma...] Posted October 13 Share Posted October 13 Here is powershell script which will cover changes. observer.ps1 - script itself - correct paths and names for files observer-task.vbs - script for windows task scheduller - correct full path to "observer.ps1" - make new task -> trigger = login -> action = this file it will run hidden This script will result in this log file [2026-10-13 12:44:17] SERVICE STARTED (Monitoring 'operid' every 1s) [2026-10-13 12:44:17] operid changed: m.jansky [2026-10-13 12:45:17] operid changed: zeiss [2026-10-13 12:49:13] SERVICE STARTED (Monitoring 'operid' every 1s) [2026-10-13 12:49:13] operid changed: m.jansky [2026-10-13 12:50:20] SERVICE TERMINATED observer.ps1observer-task.vbs 2 Link to comment https://qualityforum.zeiss.com/topic/27640-user-login-change/#findComment-156852 Share on other sites More sharing options...
