Chamfers
For small chamfers i usually do this:
  • measure both facing features ( like plane and cylinder )
  • make intersection to obtain 2x 2d line
  • make intersection with those 2d lines ( it will make a point as sharp corner without chamfer )
  • make a touch point with coordinates from previous step and fill correct angles - use plane point ( forcing vectors )
  • now you touch that chamfer
  • make theoretical line with origin from getActual("touched_point").x ( y,z ) and correct angles
  • now you can measure distances from intersections of this Theo line and measured features.
I can also post a full program with this approach
  • Like! 2
https://qualityforum.zeiss.com/topic/27642-chamfers/#findComment-156820
