[Fe...] Posted October 14 Share Posted October 14 Good evening, how can I calculate this angle? I created a theoretical plane by placing it at the intersection, but it gives me a result of 60° Any help is appreciated, thank you Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/ Share on other sites More sharing options...
[Jo...] Posted October 14 Share Posted October 14 (edited) Check the complementary angle (20)°, to see if there is something wrong with your theoretical plane or if the angle is 60°. Edited October 14 Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/#findComment-156914 Share on other sites More sharing options...
[Ma...] Posted October 14 Share Posted October 14 It's turned part, so i would scan just lines in part axis ( as viewed ) For small lines i usually do points instead of scan. If curve is available, then you can scan curve - make alignment from bestfit of curve to have correct data for small lines. 1 Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/#findComment-156918 Share on other sites More sharing options...
[Fe...] Posted October 15 Author Share Posted October 15 Please sign in to view this username. In other words, the other angle? Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/#findComment-156968 Share on other sites More sharing options...
[Fe...] Posted October 15 Author Share Posted October 15 Please sign in to view this username. Unfortunately, I don't have the curves pack Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/#findComment-156970 Share on other sites More sharing options...
[Jo...] Posted October 15 Share Posted October 15 check this angle, so you see if 60° could be right. Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/#findComment-156974 Share on other sites More sharing options...
[Fe...] Posted October 15 Author Share Posted October 15 OK thanks, as soon as I have the part I will check it Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/#findComment-156978 Share on other sites More sharing options...
[Fe...] Posted October 15 Author Share Posted October 15 It returns a result of a 30° angle, so it is not correct Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/#findComment-156990 Share on other sites More sharing options...
[Be...] Posted October 17 Share Posted October 17 I am unclear what you have tried that is giving you 60°. Did you measure a line or a cone? If you measured a line then what did you use to get an angle? Did you do the basic angle of the line? Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/#findComment-157076 Share on other sites More sharing options...
[Fe...] Posted October 19 Author Share Posted October 19 Please sign in to view this username. As you can see in the image, I created a theoretical plane positioned exactly at the intersection and a 2D line, then I inserted them into the 'angle between elements' feature." Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/#findComment-157086 Share on other sites More sharing options...
[Ri...] Posted October 19 Share Posted October 19 Please sign in to view this quote. Show us your setup of the related features, what are your nominals and results? Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/#findComment-157098 Share on other sites More sharing options...
[Be...] Posted October 20 Share Posted October 20 Please sign in to view this quote. okay, have you just asked for projection angle one or projection angle two? The nominal projection angle should be 70°, and then the projected angle should match or be whatever the part actually is. Link to comment https://qualityforum.zeiss.com/topic/27654-angle-70%C2%B0/#findComment-157172 Share on other sites More sharing options...
