[Fe...] Posted 3 hours ago Share Posted 3 hours ago Good evening, how can I calculate this angle? I created a theoretical plane by placing it at the intersection, but it gives me a result of 60° Any help is appreciated, thank you Link to comment Share on other sites More sharing options...
[Jo...] Posted 2 hours ago Share Posted 2 hours ago (edited) Check the complementary angle (20)°, to see if there is something wrong with your theoretical plane or if the angle is 60°. Edited 2 hours ago Link to comment Share on other sites More sharing options...
[Ma...] Posted 1 hour ago Share Posted 1 hour ago It's turned part, so i would scan just lines in part axis ( as viewed ) For small lines i usually do points instead of scan. If curve is available, then you can scan curve - make alignment from bestfit of curve to have correct data for small lines. Link to comment Share on other sites More sharing options...
