Approach vectors
It's approaching from your clearance plane.  You have two solutions that would work for it:
Since it is an angled hole you can use clearance distance.  You probably want to turn on the graphics to see what it will do here:
Then you can set a clearance distance that it will go to before entering the feature:
Your other alternative would be position points:
Just make sure you have one before and after your circle paths.
  • Awesome! 1
https://qualityforum.zeiss.com/topic/27658-approach-vectors/#findComment-156980
If you create an alignment to the feature at entry, you won't need position points.
All you have to do is increase the Clearance Distance.
If I wanted to approach the hole location you have, my alignment would be at the intersection of the center of the hole and the OD body.
For an example, in the attached image, see Alignment Ref #2.
Then I set the Clearance distance proportional to the Clearance Cube from Clearance Plane settings.
Now you can navigate without collisions or CMM Position Points.
With a proper alignment all of your vectors will be correct.
Edited
  • Like! 1
https://qualityforum.zeiss.com/topic/27658-approach-vectors/#findComment-157042
