Detect which Sensor is in use.
I am trying to detect which probing sensor is in use.
VAST XTR Gold
RDS CAA XXT
Can this be done with PCM or a script?
I would prefer a script as I don't have a full PCM license on every CMM.
Since I have introduced a third tier to our Probe rack for the RDS styli, I need to detect which sensor is active to trigger a message or other event to warn an operator of impending crash if the third tier is not retracted.
Eventually I will use a switch or laser to determine if the third tier is in the correct position.
https://qualityforum.zeiss.com/topic/27660-detect-which-sensor-is-in-use/
You may want to try one of the following:
executeCode("Zeiss.Calypso.OMConfiguration current at: #probeHeadType")
baseSystem().machine.machineControl.configuration.carrier
baseSystem().machine.machineControl.configuration.probehead
I'm not sure if the first and second line query the same information, but on my offline seat they returned the same result (#VASTXTGOLD).
2 and 3 might work in a formula (not tested).
Edited
  • Like! 3
  • Thank you! 1
