[Ri...] Posted 4 hours ago Share Posted 4 hours ago I am trying to detect which probing sensor is in use. VAST XTR Gold RDS CAA XXT Can this be done with PCM or a script? I would prefer a script as I don't have a full PCM license on every CMM. Since I have introduced a third tier to our Probe rack for the RDS styli, I need to detect which sensor is active to trigger a message or other event to warn an operator of impending crash if the third tier is not retracted. Eventually I will use a switch or laser to determine if the third tier is in the correct position. Link to comment Share on other sites More sharing options...
