[Ka...] Posted October 19 Share Posted October 19 Hi, Simple question, sorry... PiWeb reporting forms: General stored here: C:\Program Files (x86)\ZEISS\CALYPSO 7.4\PiWebReportingTemplates Own generic reports here: C:\Users\Public\Documents\ZEISS\CALYPSO\protocol\PiWebReportingTemplates [ Configured PiWeb Path in Calypso ] But where to store the plan-specific PiWeb forms? Neither of them works. A) C:\Users\Public\Documents\ZEISS\CALYPSO\workarea\inspections\myplan [configured inspection plan path in Calypso] B) \\fshare\machines\Zeiss\production\myplan [real store place of loaded inspection plan ] Link to comment https://qualityforum.zeiss.com/topic/27682-where-are-inspection-plan-specific-piweb-forms-stored/ Share on other sites More sharing options...
[Ri...] Posted October 19 Share Posted October 19 Typically, they are here: C:\Users\Public\Documents\Zeiss\CALYPSO 7.4\protocol\PiWebReportingTemplates Change the "Calypso 7.4" to your install name. Link to comment https://qualityforum.zeiss.com/topic/27682-where-are-inspection-plan-specific-piweb-forms-stored/#findComment-157096 Share on other sites More sharing options...
[Ch...] Posted October 19 Share Posted October 19 Moin Karsten, bei uns liegen sie z.B. auf dem Server rum. Schau mal Extras: Arbeitsumgebung: PiWeb ... schau mal was da bei Dir da steht. Link to comment https://qualityforum.zeiss.com/topic/27682-where-are-inspection-plan-specific-piweb-forms-stored/#findComment-157114 Share on other sites More sharing options...
[Ka...] Posted October 19 Author Share Posted October 19 Hi Ruchard, Well that's the origin of the own generic reports. I'm looking for the storage location for templates that are tied only to a specific program. See the third section in German: "Prüfplanspezifische Vorlage" -> Inspection Plan-Specific Template Link to comment https://qualityforum.zeiss.com/topic/27682-where-are-inspection-plan-specific-piweb-forms-stored/#findComment-157116 Share on other sites More sharing options...
[Ka...] Posted October 19 Author Share Posted October 19 Moin Marti, Ja, bei uns ( noch ) lokal nach C:\Users\Public\Documents\ZEISS\CALYPSO\protocol\PiWebReportingTemplates Die Vorlagen die ich dort ablege sehe ich in dem Reiter "Generische Vorlagen". Es gibt ja aber noch den Reiter "Prüfplanspezifische Vorlagen". Der ist leer und ich wüsste gern wohin der Pfad da zeigt. Für bestimmte Programme benötige ich spezielle PiWeb vorlagen ( leider ). Die sollen aber auch definitiv an dieses spezielle Programm gebunden sein anstatt irgendwo global oder bei uns noch lokal. Link to comment https://qualityforum.zeiss.com/topic/27682-where-are-inspection-plan-specific-piweb-forms-stored/#findComment-157118 Share on other sites More sharing options...
[Ri...] Posted October 19 Share Posted October 19 (edited) Do you mean when the template is dumped in the CMM program itself? Then, look for a PiWeb folder in the CMM program. "PiWebReportingTemplates" Edited October 19 Link to comment https://qualityforum.zeiss.com/topic/27682-where-are-inspection-plan-specific-piweb-forms-stored/#findComment-157120 Share on other sites More sharing options...
[Ka...] Posted October 19 Author Share Posted October 19 Ahhhh, We need an folder named PiWebReportingTemplates within the CMM folder. Thats a nice crypt: Security by obscurity 🙂 Thanks a lot, i will try it tomorrow morning: End of long shift now. Link to comment https://qualityforum.zeiss.com/topic/27682-where-are-inspection-plan-specific-piweb-forms-stored/#findComment-157122 Share on other sites More sharing options...
[Pi...] Posted October 20 Share Posted October 20 Inspection plan specific reports are stored in each inspection plan folder. For example if you use default inspection plan location - which is (in my case): C:\Users\Public\Documents\Zeiss\CALYPSO 8.0\workarea\inspections then inside I have Inspection plan called - Probe_Calibration_Test If you will create measurement specific report then your location for that report should be: C:\Users\Public\Documents\Zeiss\CALYPSO 8.0\workarea\inspections\Probe_Calibration_Test\PiWebReportingTemplates All measurement specific reports are set to be saved directly inside inspection plan folder - to avoid situation that you will copy program to the other PC and you will miss report required to output results. I hope that helps. Link to comment https://qualityforum.zeiss.com/topic/27682-where-are-inspection-plan-specific-piweb-forms-stored/#findComment-157142 Share on other sites More sharing options...
