[Ba...] Posted October 20 Share Posted October 20 Hello, Backstory: Zeiss had written some programs for us to measure multiple features on this part. They used curves to measure the radius in balloon 16. We are after the results of balloon 21, the center of the "16" radius to the top of the tubes. I have verified these on a vision system, and the results vary significantly from what the CMM is outputting. We aren't recording the value of the radius, just primarily after balloon 21 (0.080 - 0.100). Calypso will almost always output these results as 0.99 - 0.1 with no variation. I have measured these to be about 0.084 - 0.087 using a smart scope. We are using a Duramax, Calypso 2024, 0.5mm probe / also attempted a 0.3mm probe on an angled knuckle @ 45 deg to minimize deflection. These are fixtured with the tubes aligned with the Z axis. I have made my own copies of these programs to play around with no success at improving these features. Any suggestions would be appreciated. I feel that vision would be the best way to achieve these accurately and repeatably. Thank you! Link to comment https://qualityforum.zeiss.com/topic/27688-radius-measurement-with-small-arc/ Share on other sites More sharing options...
[Ma...] Posted October 20 Share Posted October 20 For small angle on radius you can measure their position with constraining their radius - forcing calculations with nominal radius. What i found on small radiuses ( R1.0mm; 90° ) is that your probe needs to be on correct position - so do alignments, bestfit - whatever to be on correct spot for taking points. 1 Link to comment https://qualityforum.zeiss.com/topic/27688-radius-measurement-with-small-arc/#findComment-157150 Share on other sites More sharing options...
[Be...] Posted October 20 Share Posted October 20 Locking the radius is definitely the way to go when you need the location of such a small section of a radius. You may consider also locking the X location AND using a formula to determine the X-location. It kind of depends on the tightness of the tolerance that determines that dimension as compared to the tolerance for the radius etc. Are the features in bubble 16 the same as the ones in bubble 21? I would say that they are from the picture shown. Look at the way that the feature is programmed. They may have locked the XYZ location to get a more reliable radius. They may have even done something more sneaky and difficult to program in order to get that dimension cleanly. In the most complex version of the programming, they already have the information hidden in the data and you would just have to coax it out. Even in a moderately complex version, they may have all the information that you need. Judicious use of recall feature points and formulas for nominals could get you what you want without taking any additional datapoints. Link to comment https://qualityforum.zeiss.com/topic/27688-radius-measurement-with-small-arc/#findComment-157170 Share on other sites More sharing options...
[Pa...] Posted October 22 Share Posted October 22 Locking the radius and/or location may help. I think there might be a problem with the probe size, probe dia 0.5 mm is just too big for radius .0135 (0.32 mm). But the drawing shows a "min", so if the actual radius size is significantly larger, it may work. But then you should lock the radius size similar to the actual value, not the nominal radius. In any case, vision/optics or a contourograph will be more suitable here for measurement than Duramax. But mainly in my opinion this archaic way of dimensioning should be banned. Line or surface profile is much better for such purposes. Link to comment https://qualityforum.zeiss.com/topic/27688-radius-measurement-with-small-arc/#findComment-157254 Share on other sites More sharing options...
[Ke...] Posted October 22 Share Posted October 22 Unfortunately, constrainig the location is the best option for very small radius measurements. I have noticed the following, when constraining radius position: Unconstrained: low form error, but position is way out due to small arc/lack of opposing points Constrained: position is forced to nominal; high form error (due to nominal position not being in the nominal location that it is being forced to assume) I always report the form result as a reference characteristic. Whenever possible, I try to use physical radius gages to verify CMM results. Link to comment https://qualityforum.zeiss.com/topic/27688-radius-measurement-with-small-arc/#findComment-157260 Share on other sites More sharing options...
Popular Post [Ri...] Posted October 22 Popular Post Share Posted October 22 If you have Curve - you can try out the new contour radius measurement. Seems very promising! Size - Curve Dimensions - Curve Contour 5 Link to comment https://qualityforum.zeiss.com/topic/27688-radius-measurement-with-small-arc/#findComment-157272 Share on other sites More sharing options...
[Jo...] Posted October 26 Share Posted October 26 I am having a hard time selling our engineers on using radius gauges as checks. Any advice? We are fighting so many "bad" small radiuses that it would resolve..... Our engineers are afraid a sharp spike of metal is going to jut out of the center of the radius and ruin their clearance. (But isnt that the exact sort of thing a radius gauge would resolve?) Link to comment https://qualityforum.zeiss.com/topic/27688-radius-measurement-with-small-arc/#findComment-157452 Share on other sites More sharing options...
[Jo...] Posted October 27 Share Posted October 27 A gauge "uses all points, no filter and the hull principle" so to say. Measurement uncertainty on partial radii is real. You can use a form tolerance or make the tolerances appropriate for the situation? If you are afraid existing spikes in the radius area ruiining the result, but being acceptable, you can also go the "radius existing" text- route. Link to comment https://qualityforum.zeiss.com/topic/27688-radius-measurement-with-small-arc/#findComment-157462 Share on other sites More sharing options...
[Ba...] Posted Tuesday at 05:09 PM Author Share Posted Tuesday at 05:09 PM Thank you everyone for your suggestions. We knew these measurements would pose challenges. We are going to look into other methods to capture these features. Link to comment https://qualityforum.zeiss.com/topic/27688-radius-measurement-with-small-arc/#findComment-157794 Share on other sites More sharing options...
[Ze...] Posted Tuesday at 05:21 PM Share Posted Tuesday at 05:21 PM My suggestion is to use Profile if they're looking for clearance. Profile is a surface control and doesn't care what size the radius is. It's just a stock on/stock off measurement, which should let them know if there is clearance or not. Otherwise, I would just use radius gages as already suggested to visually verify blend radii. 2 Link to comment https://qualityforum.zeiss.com/topic/27688-radius-measurement-with-small-arc/#findComment-157796 Share on other sites More sharing options...
