Calypso 2027
I used to curse PC-DMIS.  It was the worst software I had used to date ... then I started learning Calypso and boy was I in for a shock.  I deleted a probe the other day while it was still in the holder.  Don't do that btw.  It completely breaks calypso and you either have to get live tech support to fix the problem hidden deep behind a password or you have to uninstall and reinstall the software with all that implies.
I have found two other hideous bugs since then.
  • Like! 1
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158030
I wait until most of the complaints have dwindled away before I move to the newest or newer version.
We are going to upgrade to v2023 soon from 2016, 2017 and 2022.
I am still seeing issues with 2024 and specifically 2025 offline. I rely heavily on the offline working properly.
For 2027, fuhgettaboutit 😄
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158090
I skipped 2023, and went with 2024, as it's supposed to be a true 64 bit software, for more ram access. I had intended on going with 2025, but now not so sure. The simulation I did on 2027 went smoothly, so I have some hope. I did mess around some with 2025, for some reason I had to recreate all my machines from scratch, and put a number of some kind, at the end of the machine name, or I would get some weird error.
  • Like! 1
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158094
Hi Sven,
does this exception appear when you open the Basesystem?
This issue is reported in 8.0 and is solved for the upcoming 8.0.20 Servicepack, it might be that the same problem is within 8.4 and should be fixed with the next Patch Version.
Best Regards
Marcel
  • Like! 1
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158128
Never really had issues with installing updates themselves. It's just that the last release was pretty buggy at the start. Not even counting the issues with simulation, there was the weird bug slowing every plan by 30%. I used to install new Calypso version almost immediately after it was released, and had no major issues, but that 2025 memory is holding me back 😉
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158148
Sounds like an IT department that doesn't know what it's doing. My IT department gave me local admin rights, because they didn't want to support the Calypso updates. IT only gets involved with my PC's, when it's something I am not quite able to solve, which is usually network related.
  • Like! 2
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158172
Is anyone else having issues extracting features or adding points to a feature on a CAD model? It's like the mouse cursor isn't lined up with the part how it appears in Calypso. I'm clicking to add points and they're appearing like I clicked somewhere else on the model.
Also, there is a place on the right side of the screen where if I drag my model over it, the CAD model cuts off.
The Mouse cursor is where I clicked, but the point shows up way off to the left
Full Model
Model when dragged to the right towards the toolbar
  • Like! 2
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158174
Dang, yeah I'm trying to set a plane with points, so I can't use anything but the points method in the feature window.  I'm basically having to find a spot that works, click all of my points in the same spot, and then just set them manually with X/Y values. I was hoping to find out what's causing the issue or if there's enough other people having the same issue that maybe a fix is coming.
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158228
I used space points individually and verified the x y z values and vectors. I created the plane from the CAD, Then recalled feature points, unchecked the recalculate geometry button so I took the nominals from the CAD. This has worked for me. I am not sure if it is incorrect in some way, but thats what has worked for me.
  • Like! 1
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158230
Something seems fundamentally different about the interaction of the mouse cursor to the CAD window.
I *love* the new CAD cube and the ability to rotate 90° by clicking on it.  This was so overdue.
However, it seems like there may have been other unintended/untested behaviors related to CAD interaction, as reported by several users in this post.
  • Like! 4
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158236
Hello Zachary,
i've been trying to reproduce this problem but i cant with several different CAD models. Do you have this issue with every CAD model or just this one in particular?
If you could open a Software Support Ticket with your local Zeiss Support and tell them to forward it to the 2nd level we could look into it with development.
Best Regards
Marcel
  • Like! 1
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158242
It looks like the GPU requirements increased with this release. On 2025 the CAD would be smooth on any potato PC. I've installed 2027 on a PC with ancient Quadro K2000 and its noticeably slow with GPU use hitting 90% when rotating the model. The 2025 on the same PC - the card is not even breaking a sweat. Then, I've tested 2027 on slightly younger P2200 - the CAD was smooth with GPU use at 30%. Just told my IT guy he needs to buy 4 cards 😉
  • Like! 2
https://qualityforum.zeiss.com/topic/27692-calypso-2027/page/3/#findComment-158252
