[M...] Posted October 21 Share Posted October 21 Hello, how to inspect dimesion between line and plane? I want to check min. + max. dimesion. Link to comment https://qualityforum.zeiss.com/topic/27700-dimesion-between-line-and-plane-min-max/ Share on other sites More sharing options...
[Jo...] Posted October 21 Share Posted October 21 (edited) That would be parallelism. Or you could project the line into the plane. Define your endpoints and with the normal vector of the plane and the points construct lines and get the intersection points with the original line. Then you can evaluate the distance. There might be a function for that, but out of my head i can`t recall one for that... Edited October 21 Link to comment https://qualityforum.zeiss.com/topic/27700-dimesion-between-line-and-plane-min-max/#findComment-157188 Share on other sites More sharing options...
[Jo...] Posted October 21 Share Posted October 21 Basically that is the same as a two line distance with the projected line, but according to the tech guide this gives you only the shortest distance. Link to comment https://qualityforum.zeiss.com/topic/27700-dimesion-between-line-and-plane-min-max/#findComment-157192 Share on other sites More sharing options...
[No...] Posted October 21 Share Posted October 21 I assume you want the distances perpendicular to the plane? Then you won't need more than two distances: Either the line is parallel to the plane, then one dimension would be enough. Or it is angled, then the min and max are at the end points. No need to measure inbetween. So extract the line's end points with Construct / Point / Point from Line. Then create two projected point distances (Construct / Distance / Projected Distance), select the point(s) and project on the plane. Link to comment https://qualityforum.zeiss.com/topic/27700-dimesion-between-line-and-plane-min-max/#findComment-157194 Share on other sites More sharing options...
[M...] Posted October 21 Author Share Posted October 21 I can measure two distances. But Id like something as Liner size with Two-point size with SX and SN Link to comment https://qualityforum.zeiss.com/topic/27700-dimesion-between-line-and-plane-min-max/#findComment-157202 Share on other sites More sharing options...
[Jo...] Posted October 21 Share Posted October 21 (edited) You could try and build a cylinder out of the information you got and use "check linear size" on that. Edited October 21 Link to comment https://qualityforum.zeiss.com/topic/27700-dimesion-between-line-and-plane-min-max/#findComment-157210 Share on other sites More sharing options...
[Ma...] Posted October 21 Share Posted October 21 You can use caliper point on selection. 1st in direction to a plane and 2nd opposing - this way you can get 2 min/max points. Or in same way you can use parallelism ( line against plane ) and report min/max point - this flag with biggest deviation can be used as a point in projected distance. Link to comment https://qualityforum.zeiss.com/topic/27700-dimesion-between-line-and-plane-min-max/#findComment-157212 Share on other sites More sharing options...
[Ma...] Posted October 23 Share Posted October 23 Hi team , i solve this measurement for one customer , examples see below. - construct line / or points on surface - construct points from line - construct element group from points - evaluate element group (max/min) - it depents on datum system (i used plane as one of axis) 1 Link to comment https://qualityforum.zeiss.com/topic/27700-dimesion-between-line-and-plane-min-max/#findComment-157328 Share on other sites More sharing options...
