[Ca...] Posted October 22 Share Posted October 22 Hello CMM Team, I want to select dynamically a set of dimensions, so we can create ad-hot miniplans This is an example. Normally all the checkBoxes are selected, but if you select only a few, a LIST with these dimensions or characteristic is created and ready for a PreSettings. The Issue is when I try to measure some Characteristics that need features not defined in the alignment. Here an example of the questions by the Calypso system: Some ideas to avoid create a list ddME before calling setCF. 1 Link to comment https://qualityforum.zeiss.com/topic/27720-setcf-for-dynamic-selection-of-characteristics/ Share on other sites More sharing options...
[Je...] Posted October 23 Share Posted October 23 (edited) you can use addME("Feature1", "Feature2",etc) to predefine all needed Features. If you use this, you will have to run from feature-list. Edited October 23 1 Link to comment https://qualityforum.zeiss.com/topic/27720-setcf-for-dynamic-selection-of-characteristics/#findComment-157308 Share on other sites More sharing options...
