[Ca...] Posted October 22 Share Posted October 22 Hello CMM Team, I want to select dynamically a set of dimensions, so we can create ad-hot miniplans This is an example. Normally all the checkBoxes are selected, but if you select only a few, a LIST with these dimensions or characteristic is created and ready for a PreSettings. The Issue is when I try to measure some Characteristics that need features not defined in the alignment. Here an example of the questions by the Calypso system: Some ideas to avoid create a list ddME before calling setCF. 1 Link to comment https://qualityforum.zeiss.com/topic/27720-setcf-for-dynamic-selection-of-characteristics/ Share on other sites More sharing options...
[Je...] Posted October 23 Share Posted October 23 (edited) you can use addME("Feature1", "Feature2",etc) to predefine all needed Features. If you use this, you will have to run from feature-list. Edited October 23 1 Link to comment https://qualityforum.zeiss.com/topic/27720-setcf-for-dynamic-selection-of-characteristics/#findComment-157308 Share on other sites More sharing options...
[Ca...] Posted 4 hours ago Author Share Posted 4 hours ago I got an issue in the Zeiss Calypso system: I have experimented with the external software to automate the Characteristics to measure (Like a MINIPLAN but "on the fly"). 1. I have created the specific instructions addME for the correspondent Characteristics. They aapears in order of excecution of FEATURES. (regardless of redundancy) and the same experiment with / without redundancy, in order and out of features order (EVER RUN FROM FEATURE LIST) addME("IntCone","IntCone","2D Curve1","2D Curve2","2D Curve3","2D Curve4","BottConePlane") //===> (redundancy "IntCone" and in FEATURES order) addME("2D Curve2","2D Curve3","IntCone","2D Curve1","2D Curve4","IntCone","BottConePlane") //===> (redundancy "IntCone" and out of FEAT. order) addME("IntCone","2D Curve1","2D Curve2","2D Curve3","2D Curve4","BottConePlane") //===> (no redundancy in FEATURES order) addME("2D Curve2","2D Curve3","IntCone","2D Curve1","2D Curve4","BottConePlane") //===> (no redundancy and out of FEAT. order) [ in ALL CASES the program RUN without problems and in order of FEATURE LIST ] no issues ONLY WHEN I WRITE EXPLICITY THE CODE on PCM ] 2. When I try to write the code using external txt file automatically, here the PCM addME(readListFile(FOLDER_BASE + "SelectorDim-" + PLANVERSION + "\addMEList.txt")) //===> addMEList is created on the fly THEN I GET THIS ISSUE OR MESSAGE: SOME IDEAS PLEASE TO MAKE A REAL AUTOMATION WITHOUT THESE MESSAGES Link to comment https://qualityforum.zeiss.com/topic/27720-setcf-for-dynamic-selection-of-characteristics/#findComment-158488 Share on other sites More sharing options...
[Ca...] Posted 2 hours ago Author Share Posted 2 hours ago //============> SOLVED SOLVED SOLVED <======================== When you want to AUTOMATE at-hot or on the fly a PLAN!!! 1. Create a text file but not in the same format as a handwritten "addME("ME0001",...,"ME000n") but in the format: ME0001 ME0002 ... ME000n That is, with the newline or return at the end of each line 2. Then, you can with ===> readListFile() obtain the new LIST of ME: addME(readListFile(PathFile)) That is because the internal format of addME is not the same defined or showed in the sentence addME("ME0001",...,"ME000n"). This was my ERROR. Well community, I try to hold the FEATURE LIST order, but I have experimented and any way, not order, redundancy....order...alll was functional and OK Link to comment https://qualityforum.zeiss.com/topic/27720-setcf-for-dynamic-selection-of-characteristics/#findComment-158492 Share on other sites More sharing options...
[Ca...] Posted 27 minutes ago Author Share Posted 27 minutes ago (edited) Here the format of the txt file to use in the addME. I was experimenting with order, redundancy ... and all models were OK, but try when possible, to use in FEATURE LIST. Edited 24 minutes ago Some commentary about the picture. Link to comment https://qualityforum.zeiss.com/topic/27720-setcf-for-dynamic-selection-of-characteristics/#findComment-158498 Share on other sites More sharing options...
